Question about Canon imageCLASS MF4150 All-In-One Laser Printer
No printing on Mac OS 10.5.1
I bought this printer two montw ago and it works fine with Tiger 10.4.11 printing software ( not Canon's), except for the scanning feature. Since I installed Leopard, the printing software detects the MF4150 and shows to be printed, but it cannot print. the same thing happens with my Pixma MP800.
  • 1 more comment
  • DeezNutz Nov 28, 2007
  • acew Nov 08, 2008
    I can not locate a Mac-compatible driver for my Canon imageCLASS MF4150 All-In-One Laser Printer. Where did you find yours? I am on Mac OS X 10.5.5
  • Anonymous Mar 30, 2014
    My cannon pixma MX472 is connected to my Mac and shows an idle status and won't print.
Check under the Apple site for this issue. I use Leopard and can copy and print with this machine. I have not tried the fax, however, I assume  it will work. The scanner does NOT work with least yet...I am not sure if it is Apple or Canon or both who are at issue for this. As per the post below, the duplex works just fine for me. You may want to consider the possibility of removing the current drivers and reload the one's currently posted by Canon.
Duplex Printing
Apr. 19, 2007
Archon Fung
I figured out how to make duplex printing on the MF4150 work! Canon Tech support says that duplex printing is not supported, but they are mistaken.
Here is what you need to do:
1. go to the Canon site and download the latest UFRII driver (v1.5) and install it
2. in the application, go to page setup and select "Format For:" MF4100 Series [this was what I did not realize]
3. then, when you go to print, select the finishing tab, and then select 2-sided printing.
If you skip step 2, and you application defaults to "format for any printer," the 2-sided option will be greyed out. Other printer drivers do not require this, but the Canon driver does.
Posted on Dec 16, 2007
  • rodiau Oct 14, 2010
    I had to add an extra step. I have the newest driver as of 10/10/10. I followed steps 2
No power
Posted on Jan 07, 2008
HP Photosmart C6280 Scanner not found with Mac Tiger
I'm using a software called VueScan, which has drivers for almost all scanners and works well. Maybe you should test it?
Jan 27, 2014 | Apple Mac OS X 10.4 Tiger for Mac
Cannot find driver/software for my dusty Canon imageCLASS MF3240 on mac OS 10.7 Lion?
There is no driver for your printer to work with OSX. It was for Windows OS only. AND Apple does not support this particular model either.Link below list support printers by Apple OSX>
Jan 08, 2013 | Canon imageCLASS MF3240 All-In-One Laser...
Pixma Mp630 dont sacnn and dont print Cd with Mac OS X 10.6
I can sympathise as a fellow MAc OSX user!
Make sure that you have all the installation files shown at the following link
In Mac then start Solution Menu from the menu bar, select the Go menu, Applications, Canon Utilities, Solution Menu, then double-click Solution Menu. Select
Use Solution Menu to get the information on the machine or change the print settings by only clicking buttons on a screen. With Solution Menu, you can start the software applications supplied with the machine or display the operating instructions. It also provides you with the information on troubleshooting.
If you get problems then please come back to me for assistance with details of what you have done and what errors you get etc.
Sep 30, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Double Sided printing of PDF files
you have to set the printer properties to do double sided printting
Sep 11, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Software setup won't automatically run
in sert disc on the computer, goto your computer se t up ans select run.
Jan 18, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Mac OS 10.5 Leopard
two issues here..
compatibility of Epson with Leopard..and also the drivers will need to be postscript compatible..not an easy task.
Aug 18, 2008 | Epson Stylus R380 InkJet Photo Printer
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Communication error
Marky12, if the printer works fine on the vista system then you can eliminate a hardware fault. sounds like a driver or install issue. remove the printer completely from the mac (uninstall software, drivers and unplug) then go to, choose your countrey and head to the support and downloads section. Get the latest drivers for mac/tiger and reinstall the printer (make sure you have restarted the mac in between uninstall and reinstall) and most important !!! dont plug in the usb cord until the driver install tells you to
Good luck
Feb 28, 2008 | Office Equipment & Supplies
Printer Busy message
check your mac connection settings, change if needed, try install new printer.
Dec 07, 2007 | Konica Minolta bizhub C250 All-In-One...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
781 people viewed this question
old marine
old marine
