Question about HP Photosmart 2610 All-In-One InkJet Printer
HP Printer /scanner problem
HP Lap Top also connected to network though Lynksys. Laptop has XP operating system. All-in-one 2610 Photosmart installed with original HP disc and has no operating problems.
However in the Dell E-521 with Vista Premium the scanner will not work and when you go to control panel, the All-in-one printer has disappeared. When you have it search for printer,it will ask you if you want to use driver already in computer, it will install printer,but not the rest of the files needed to scan with Printer will print find ,but can't scan. When you look in the HP files,it seems all the files are there. I can reinstall using the disk I have ordered for Windows Vista, and have done so numerous times,but after a few days the same disappearance will occur. It seams a HP excution file dissapears somewhere.
Re: HP Printer /scanner problem
Are you running a space cleanup utility? HP unhelpfully uses the .tmp extension for live files, ensure you're not deleting them. I got "Scan.msi not found" and had to reinstall my AIO software every time until I told WinOptimiser to stop deleting .tmp files (except in the genuine TEMP folders).
Posted on Mar 17, 2008
0 characters
3 Points
I do not have an installer for my HP Photosmart 2610
you can download the driver from hp website. Just follow the steps in downloading the driver
1. go to 2. enter your product number which is (photosmart 2610) 3. choose HP photosmart 2610 all-in-one 4. click software and driver downloads 5. choose your operating system and click next = to know your operating system just click start then right click my computer or computer then click properties 6. click driver - product installation software 7. click HP officejet and photosmart full feature software and drivers 8. click download then run
May 16, 2011 | HP Photosmart 2610 All-In-One InkJet...
I want to wireless print to my HP 2610 printer through an Airport express router using Windows xp. When I attempt to install the driver I get a message that a printer cannot be detected on the network...
First install the Printer with USB connectivity.
Then insert the printer driver CD again. You will get the Add a Device option this time on the Welcome Screen.
Select it. Now before you continue, just add the exceptions to the firewall list.
Perform the steps given on the above document to add the exceptions to firewall.
Then Make a right click on My Computer Icon on your desktop.
Go to Hardware Tab. Select Device Mananger.
Go to View Tab on Device manager and select Show Hidden Devices.
Then search for Multifunction Adapter. Uninstall the printer icon under it.
Now click on Add a Device.
Try installing now.
May 28, 2010 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart C6280 not visible as printeroption though installed
this will usually happen if you're disconnecting the USB cable from the computer and putting it back on a different USB ports. try to connect it to where it was working before. this is also true for other USB devices such as scanners and webcams
Mar 13, 2010 | HP Photosmart C6280 Printer
I have a 2 year old hp photosmart 2575 all in one. initialy i had it connected to a normal computer but have removed it and would like to connect it to a lap top ( year old) as it is easier for me. it wont...
Go to HP website and downlad driver.
It will ask you to select Operating System and then it will list available downloads.
I'd recommend the HP Photosmart Basic Print and Scan Driver because it is a smaller download size without having to install the other unneeded software in HP Photosmart Full Feature Software and Drivers
Dec 12, 2008 | HP Photosmart 2575 All-In-One InkJet...
Hp 2610 scanner
I have lost my cd to my 2610 photosmart printer
Aug 28, 2008 | HP Photosmart 2610 All-In-One InkJet...
I have a hp deskjet f2180 all in one printer scanner copier we have tried to add to my lap top but the lap top does not recognise the hp deskjet f2180 and we dont know what else is compatable with
What operating system are you running on your laptop? This model only supports Windows 2000/XP/Vista and Mac OS/X. Make sure you have installed the printer USB drivers (included on the printer software CD) first. If you are connecting the printer directly to the laptop, all you should then need to do is connect the printer to the mains power, turn it on, and connect the USB cable between the printer and the laptop. If you are connecting to a printer that is connected to another computer, you mus make sure printer sharing is enabled on the computer the printer is physically connected to.
I may be able to provide a better solution if you can provide more information on your Laptop operating system and how the printer will be connected.
Jun 15, 2008 | HP Printers & Copiers
Photosmart 3310 is on network but not recognized wirelessly
Sounds like another Vista Bug, i would check the HP site for this issue and if its under warranty, contact HP. If you have alot of Blue tooth devices hooked up, it may be that its trying to use another device in its place or the signals are getting crossed, im not positive.
Its like when you have to many network drives all hooked up and you plug in a USB device, Windows pops up those anoying bubles saying its detected, but in My computer it doesnt show.
So bassically you have to right click my computer, manage, disk management listed uder storage, right click on the device or drive and change the drive letter to something like " W" or " Z" or anything not in use.
It may be a siomilar case with your bluetooth, youo may have to much stuff connected. Try redoing everything like you have so many other times before, and then limiting how many bluetooth devices you have connected at the same time. see if theres a difference.
Hope this helps.
Dec 25, 2007 | HP Photosmart 3310 Printer
If it was installed on the network / ethernet.
The delete the printer from the folder.
Add a device with the Cd that was shipped or download driver from
Kindly do mention the setup e.g, win o/s , router, laptop / destop etc.
Dec 21, 2007 | HP Photosmart 2610 All-In-One InkJet...
Hp photosmart 2610
is your operating system Vista.......good luck. my printer worked fine w/XP, scanning and fax functions do not work to date with Vista.
Oct 28, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
197 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
