Question about iRiver iFP-799 MP3 Player
I Upgrade my player but then doesn't works
Before upgrade my player to v195, the player it was seems to be fine but when the format process ends up, the player just turn on and then turn off all the time.
Turns on 3 secs and then it seems like a ciclic reboot process.
I can't connect to PC to reflash it.
Could you help me please??
  • Apocalipsis Nov 26, 2007
    i hope that exist this buttons combination cause i can't reflash the firmware because like i said before, it's impossible to connect the device to the PC
  • 20 Answers
Call support there is a combination of buttons which will hard reset device try that first if not try to reflash firmware
Posted on Nov 26, 2007
Upgrading to windows 7
When you first boot from the win 7 disc there is a option to format or delete a partition.Do both.This will erase all vista information and allow only win7 to be installed.
Nov 03, 2011 | Gateway LX6820-01 Desktop PC
File or directory is corrupt or unreadable
try your mp3 on some other comp.if it doesn`t work then you have to reset it or if possible you have to format it.
Jul 08, 2009 | RCA TH1101 MP3 Player
My mp3 player says initializing
Same here...I hate Phillips right now
Aug 16, 2008 | RCA M4204 MP3 Player
On my rca pm3 player it is stuck on initializing it will not turn off by pressing the turn off button
I have not tried this yet but RCA support sent me this.
I suggest updating the firmware on your player. After upgrading the firmware on your player, you must use the easy rip software. This will avoid problems in the future and keep the unit updated
1. Go to
2. Go to FAQ’s in search enter M4204
3. Download firmware upgrade
4. Hold play/pause button for 15 seconds
5. Hold menu button for 10 seconds
6. Attach M4204 via USB cable while holding play/pause button
7. This should start the firmware upgrade
8. Possible an error message of “cant write to disk” will pop up
9. Firmware upgrade will end with error do not close
10. Go to My Computer find the drive that holds the MP3 player
11. Right click scroll down to format, format the player
12. Run firmware upgrade again
Aug 04, 2008 | SanDisk Sansa m230 MP3 Player
Please help me
Upgrading the firmware version is a different process from formatting the player. You will need the installation given along with it to upgrade the firmware for it. Else you can refer the mannual to learn how to Unlock...!!!
Feb 10, 2008 | Coby MP-C7097 MP3 Player
Boot error and formating
Try formatting it in FAT 32 or FAT 16, the player sometimes can't read a different filesystem.
If that doesn't work, try upgrading the MP3 firmware, you can download it from the RCA Website (
Follow the steps carefully or you can render your player useless.
After the upgrade, the update program will format the player automatically with the correct filesystem.
Feb 07, 2008 | RCA OPAL M4001 MP3 Player
When i turn on my nw-e107 it just simply turn on and off!
try formatting through the mp3 player. go to menu -> advanced -> format -> yes.
Dec 07, 2007 | Sony NW-E107 MP3 Player
Firmware upgrade
Only 2 things to try
1. try formatting the player again
2. try upgrading the firmware again
if no luck then it will have to be returned for fixing. There are warnings about not completing the upgrade process. Don't mention the above when returning it for repair under warranty.
Dec 02, 2007 | Samsung YP-K3 MP3 Player
Sansa e260, with Rhapsody. Sansa turns on, off, on, off continuously
Uninstall the MTP device in your hardware device manager, or remove it using add/remove hardware in control panel
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
-Tha Mp3 Doctor
Oct 16, 2007 | SanDisk Sansa e260 MP3 Player
Formatting the player memory
This process worked for my m25:
1. Download v1.11 firmware file from
2. With USB cable disconnected, turn off the m25.
3. Press Power while holding Menu button until UPGRADE is shown.
4. Connect m25 via USB cable.
5. Run the firmware downloaded in step 1.
6. Disconnect the USB cable, and the m25 should start a normal.
Dec 24, 2005 | Motorola Mobility M25 MP3 Player
iRiver iFP-799 MP3 Player Logo
50 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
