Question about Panasonic PT-51HX41 51" Rear Projection Television
PT-51HX40b chassis BP819
Looking for service menu setup for convergence,need tv service codes
  • 9 more comments
  • ladywinn
    ladywinn Dec 08, 2007
    I now have service menu for setting convergence. IF anyone else needs this information i will post it !
  • Tv hates me Dec 30, 2007
    Myself as well, I've been looking for anything resembling a service manual for months. Is there anyway you can email me everything you have? Or post it on here.
  • ladywinn
    ladywinn Jan 27, 2008
    what is wrong with your sets? The tv was repairing at the time had no high voltage replaced NTE2793 hori out put,onced tv come on it had convergence problems so I had to replace(2) STK392-120s after doing this i had to realine complete convergence circuit so i needed service code for techicians only! once inside this menu if you do not know what you are doing changing wrong values can shut tv down for good.So let me know ,what it is that you are needing help with.
  • ladywinn
    ladywinn Feb 06, 2008
    something is really wrong with these postings .
  • ladywinn
    Go to web site that i have listed that is where i found information on how to get into service menu for convergence.
  • audiotom Aug 23, 2008
    Just went to converge a PT-51HX40B and diiscovered I was working from a different models service manual. I could get up to the red CHK but no farther. I have searched through everything posted about this model but the convergence access seems to have been deleted. If you have a moment and would not mind, it would be a big help.
    Thanks!
    Tom
    audiotom@hotmail.com
  • enriquez13 May 04, 2009
    hello....my problem with the TV is that it does not seem to respond to the steps to go into service manual....i'm trying to go into the service mode to change convergence settings....i tried the link above ..but it does not work......if anybody can give me some hints on how to get to the service manual and converengence i'll highly appreciate....thanks a lot....my email is enriquez13@hotmail.com
  • codyecp May 11, 2010
    My email is codyecp@gmail.com. THank you!
    OK, I have a problem, a little more in depth, but it sounds like what you are talking about with your first posting Ladywinn! WHen I went to turn my set on, (same model as listed) it would sound like it was powering up and then after about 5 seconds it would click again and shut down. I saw another posting that said it was the convergence amps, so I replaced those. Still have the same problem. I am wondering what else it could be? The guy who posted was premtech, and he said to replace any 2.2. ohm 1w resistors in front of the convergence amps that had changed value. Could replacing make a difference or should I look elsewhere? ANYONE PLEASE HELP!!! I have no TV now and it sucks!
  • whisky7 May 11, 2010
    I would also like any service manual or convergence solutions of codes, as I have just posted my problem here and looking for some answers. Thanks! email me at tnbarbee@centurytel.net
  • ladywinn
    ladywinn Mar 15, 2011
    When it comes to setting Convergence on this Model you must have all of the Service Menu
    Entering Into Convergence is Not an easy Task ! Directions and steps to enter and exit are very important. If you are not sure of changing Values then Please Take Set to an expert, Changig wrong values can really Mess TV up.
If you get to the red chk press the power button on remote numbers should appear lower right each time you hit power button nummbers change keep going till 00v00 appears press ch up then it should read oovo1 at this time press vol up now your ready
press 1 to toggel colors
use vol and ch buttons to move cursor
press mute to choose to addjust
press7 to save data
good luck
Posted on Mar 08, 2009
I dont have the time right now but i will tell you how to set convergence step by step also go to http;/www.freelists.org/ar chives/teachassist/09-2005msg01112.html Titled (TechAssist) RE; Panasonic model pt51hx40b how do you get into converg menu? Print this out!
Posted on Jan 29, 2008
Would someone please email the service manual and setup code. I see I can get the whole convergence board for around $100 so I am willing to attempt the swap myself to save 300-400 dollars. Thanks,
email bytesighsltd@sbcglobal.net
I am having problems with my tv. I could use the manuel too.
Thank you, Mark
mi061976@yahoo.com
Posted on Jan 26, 2008
Hello Ladywinn
i m interrested !
Posted on Dec 09, 2007
Panasonic PT-51hx40b projection TV powers off when I try to turn it on
Not sure if the transformer is bad or something on secondary side is pulling the voltage down--if replacing it cured the issue you did good.
If not try to disconnect at source on secondary side to see if with no load the voltage comes up.
Looking for either the xfmr to be bad or something shorted pulling the voltage it creates down.
May 14, 2012 | Panasonic Televison & Video
I have a PT-47WX53 that has one vertical bar down the middle of the screen. Barely visible in a purple hue and about 3-4 inches wide. I'm looking for some suggestions. Thanks
A few simple things you may try. Under your menu on the tv look for convergence or it also may be under setup. Run the convergence setup and follow the on screen instructions. If the tv fails to converge while in setup you may need to replace some things however the parts are very very cheap. If your convergence setup works and you still have a bad picture, and or both, meaning the tv's convergence wont align then you may need 1 or 2 IC's and maybe need to change your coolant in the tv's RGB lens...all can be done with little experience and for under 50 bucks. I can give more detail if needed.
Dec 28, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Service code
Follow this path for the service menu.
Select sound menu on remote, set BASS to max and then TREBLE to minimum now press the INDEX key on the handset and VOL- on the TV, this should get you into the basic setup menu.
Jul 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51HX40B convergence issue
Hi.....
Bit of a long shot but have you tried this??
http://oreilly.com/catalog/htheaterhks/chapter/hack12.pdf
Hope it helps!
Richard
Apr 28, 2008 | Televison & Video
Panasonic PT-47wx49E
you have to go into service menu to reset convergence after changing ics.I never posted this because if you do not know how you can shut set down.which chassis do you have ? There is 3 diffenert ways to enter into service mode for convergence.
Apr 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Convergence and such.
GO to www.repairworld.com there might be someone who knows this problem. Hope this might help
Nov 13, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Pt-47wx49e service mode
It sounds like the convergence amplifier IC for the red crt is at fault. To check this, go into your user menu and pull up the red convergence. Try to move it up/down or side to side(it doesnt matter). If it moves up and down, then the vertical amp is working. Likewise if it moves side to side, then the horizontal part of the IC is working. If it dosen't move at all, or only moves up/down or side to side, then the IC is bad. There are 2 large IC's on the chassis, mounted to large heatsinks. They have STK392-110 or some variation of an STK392. If yow feel that the IC is bad, change the ic BEFORE you go into the service mode, as you wont need it if the ic is bad. To get into theservice mode: 1 make sure tv is in cable mode 2 set sleep timer to 30 minutes 3 tune to channel 124 4 use volume down on front of set to turn volume all the way down. ( writing will appear in the top left corner). 5 use remote control and press the power button. 6 the 7 button on the remote will put it convergence mode. Good Luck!
Jul 26, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
762 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
