Question about Xerox Computers & Internet
Xerox docucolor 252 code 094 321 - Xerox Computers & Internet
  • 798 Answers
SOURCE:
  • 6 Answers
SOURCE: want to copy images from notebook paper without blue lines apparent
yes, you are loking for border erase function. when you find it then look for what looks like two peices of paper side by side, you will then possible be allowed to adust the sixe of the erased area
Posted on May 13, 2009
  • 24 Answers
SOURCE: docucolor 252 fault code 047-310
This error code indicates that the Xerox is not communicating with the finisher. The recommended method to resolve this is to power off the Xerox, wait 3 minutes after power is off, unplug the machine from the wall, wait 1 more minute and plug in and restart. If that does not help, it will require a call to the service number: 800-821-2797
Posted on Jun 10, 2009
  • 241 Answers
SOURCE: Fault 127-210. Printer functional but can not connect to command Workstation.
i think it is the problem of Fiery installation
recently i am gone through the same
but i got some other code
u can try by installing fiery
Posted on Oct 08, 2010
  • 5370 Answers
SOURCE: Xerox DocuColor 3535 Copier Problem
116-325 RAP An error occurred in ESS fan rotation:---------Try reset procedure:-- to correct your issue:
Simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel.
If the problem persists try:
Hold the 6, the Stop, and the Power Save buttons.If still it comes again,---------
Hold the 4, the Stop, and the Power Save buttons .If still it comes again ,-------
Hold the 3, the Stop, and the Power Save buttons .If still it comes again then there is internal problem with cooling fan .The ESS fan module has to be replaced.The part number for ESS fan module is
127K32920.To order this part you can order it from online website.click this link directly to order the parts:---
http://www.iteminc.com/parts_docucolor_1632_2240.htm
this will help.Thanks.Helpmech.
Posted on Jan 21, 2011
  • 343 Answers
SOURCE: I am sending files from
Hi Pat,
We had a problem in our print shop similar to this, it was caused by the heat when the toner is fused to the paper, it actually shrunk the image from heat. To test this theory try running the job on the heaviest card stock you have and see if it is still smaller. In any event the only way we could work around this was to send all jobs out at 100.6% on text and 100.4% on card stock. I was told unofficially that the update from xerox actually does something similar to this but only works when the image is copied off the glass. You may have to adjust the percentages and also make sure that you are setting the copier to the closet gsm of your stock. The heavier the stock the more heat it needs to fuse the toner, so try running on the lowest gsm setting you can; but beware if you set it too low the image will scratch off the paper.
Thanks for using FixYa,
Posted on Jun 29, 2011
Docucolor 252 facultad code 047-210 hoy do you Fix this?
may be offset catch tray. Just unplug the cable try again.
Feb 12, 2014 | Xerox DocuColor 242-252-260 PS
Xerox docucolor 252
http://www.support.xerox.com/support/docucolor-242-252-260/support/enus.html?associatedProduct=dc242-252-260-built-in-controller
Replace any new toner you put in the machine and shut it down for 2 min then power back on. If that doesn't fix it you will have to call Xerox service to replace a sensor that may be broken.
Jan 03, 2014 | Xerox Office Equipment & Supplies
Computers & Internet Logo
53 people viewed this question
Top Xerox Computers & Internet Experts
Aditya Agarwal
saurav777
Level 1 Expert
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
