Question about Bosch Washing Machines
Bosch WAA28160GB front loader blocked
The washing machine will not empty water. It is propbably blocked. I have checked the filter. How to I get to it to unblock it.
  • Bosch Master
  • 744 Answers
Bosch WAA28160GB.This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
Leaking from bottom centre of door when closed
Posted on Oct 11, 2009
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
Not spinning
Axxis+ WFR 2460 Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Dec 28, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Dec 09, 2008 | Washing Machines
Bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Jul 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Pump blocked message
next time u clean the filter when it is empty of water. put your finger in the whole and u will find somthing wound round the impeler of the pump remove what ever is obstructing and u will have no more problems make sure u unplug the machine b4 you start doing this good luck
Sep 03, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Open Questions:
Bosch Logixx 8 washing machine Powers OFF itself when filling water in the softening stage I have a 7 years old Bosch WAS32742AU/08 washer, it will wash, rinse then will power itself OFF with nothing on the display when it reaches the softening cycle where it begins to fill water, there is about 10mins left in the cycle. I can turn the dial OFF then back to the same program to resume the cycle, it will start filling with water again in the softening stage and power off again. I've checked the water level pressure switch hose and cleaned the chamber, I dont't think there is a problem with that because it works during the cycle until the softening stage. I can run and complete the Drain only cycle, Rinse only cycle, Spin only cycle and 15min Quick cycle without interruptions. It's only programs that has the Softening part of the cycle it powers off when filling water in the middle dispenser compartment during the softening stage where Valve 1 and Value 2 are open. I don't even use softener and the compartment is clean. The current work around is when it Powers OFF during softening, I turn the dial to OFF then select the rinse only cycle to complete the washing. I got into the Valve test mode and found that Value 1 and Valve 2 tests are OK individually but when it V1 and V2 are both ON to fill the middle softener dispenser compartment it wont stop filling and eventually the machine powers off. I posted a video of the test here: https:/ / streamable dot com/n1gw6 https:/ /player dot vimeo dot com/video/264199360 Do you know what the problem could be?
Apr 11, 2018 | Bosch Washing Machines
Washing Machines Logo
316 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
