Watches Logo
Judith Grohe Posted on Jan 14, 2019
Hi I'm Judy. I am 72 years old and not "hi tech" . My watch shows correct Date but not the correct time. How can I set the correct time on the watch? Simple directions would be much appreciated.
  • Jean DeLauche
    Jean DeLauche Jan 14, 2019
    Hello, Judy - What is the make and model of your watch? I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
5 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 11, 2009
SOURCE: unable to set day/date/year &time
Follow this link and download instructions for your watch:
http://www.armitron.com/watch_instructions.asp
Do not forget to rate, please.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 24, 2009
SOURCE: SETTING (DIGITAL) DAY/DATE ON THE FOSSIL JR9387
Follow this link and download proper instructions:
http://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
Rate me, please.
dennis
  • 79 Answers
  • Posted on May 15, 2009
SOURCE: Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
Anonymous
  • 47 Answers
  • Posted on Aug 06, 2009
SOURCE: date setting in a citizen eco-drive calibre 8700 watch
http://www.youtube.com/watch?v=RF3hC1hgZz4
hope this link illustrates u better
All the best,
Prince
Anonymous
  • 2501 Answers
  • Posted on May 03, 2010
SOURCE: how do you set the time and date on the addidas
If you haven't got the instructions,you can get them from their web site (www.adidas.com/campaigns/watches_fw07/content/index.asp?)
Click on "instruction manuals" in the menu on the left, choose your country.
You will be presented with a series of generic instructions from which you should choose the ones that suit your watch
Has no leap yr. went from 2/28 to 3/1 cannot coordinate time
  • Auto Calendar (pre-programmed until the year 2039)
that means, you need to set up correct year in order to show leap years.... and then it will show you also correct day, after you will set it up correctly..... http://support.casio.com/storage/en/manual/pdf/EN/009/qw1545.pdf
check page 2
How can I set the date on my watch? I could set time and alarm but I couldn't set the date .
Hi ajcruz_h,
To set the digital time and date on your Timex, please follow the steps below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
How to set time on a 1440 timex watch
Hi tsgoode99,
Timex Digital Watch
Hope it helps.
Set time on wr50m watch
Hi capttimpcb,
Hope it helps.
Would like to learn how to set time on on Timex 1440 sports watch
Hi danielrob676,
Timex Digital Watch
Hope it helps.
Hi i forgot how to set the time on my timex 1440 sports watch
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Mid Size Sports 1440 Black Nylon Strap Watch: hi i forgot how to set the time on my timex 1440 s...
Hope it helps.
1440 date change
Hi jhnmeserole,
Timex Digital Watch
Hope it helps.
How do I change the time and date on my Timex 1440 sports watch? Cindy
Hi Cindy,
Hope it helps.
How do i set the time and date
Hi hernandez415,
Timex Digital Watch
Hope it helps.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Watch Expert? Answer questions, earn points and help others
