Question about IonizAir (AR3397) Air Purifier
Ionizair Model: P4620 Problem
The check light came on, so we cleaned it w/ the brushes that came w/ it, but now it still won't go off.
  • Anonymous Mar 03, 2008
    It worked perfectly for a few days, but now the red light "Check" stays on. The filter is clean, not wet, never was wet. Doesn't work. I am mighty disappointed.
The blades come out of the top and can be cleaned gently with detergent for dishes and a soft bristled tooth brush.
Posted on Dec 15, 2007
  • NWDon1 Dec 15, 2007
    Do Not Replace Blades or turn on machine ever if there is any moisture there must be absolutely no moisture before turning machine on again.
How do I clean cat hair out of spin brissels
Hey there! The brushes can be removed for cleaning. With the handle in the upright position, tilt the cleaner back so that handle rests on floor. Grab brush assembly and pull firmly. Remove hair and debris from brushes. You may clean the brushes under running water. If for some reason you are not able to clean the brushes, replacement brushes can be ordered by following the link below.
Search Results
Jun 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
Brush wheel not spinning
it can be belt or clutch failed. put the vac on its side and on the bottom there will be either two push clips or 2 screws remove them or push them and pull the bottom off. then when this is off you will see were the belt is for the spinning brush. if the belt is still on then the clutch has gone in the motor if the belt has gone take out the broken part and get a new belt, fitting new belt you need to remove the spinning brush it is either clipped in or slotted in , clipped is push the clips out to the side and lift the brush out, slotted it will just pull out. clean out the brush before putting back in also check the brushes bearing to make sure it moves easy as a failed bearing do to carpet string etc can burn the belt, any belt that has been burnt in this way should be removed and changed as it will damage the hover if still used after this part has been cleaned replace all parts and then turn on dont and it pluged in mains while you are doing this and dont use until it has all been fitted back..
Mar 26, 2014 | Kenmore Intuition Upright Bagged Vacuum...
Do not know what to do when the service required light is on on a Alpine LIVING AIR XL15 IONIC AIR PURIFIER OZONE XL 15. How do I service it?
Hi JoAnn,
Alpine purifiers need periodic cleaning, as dust and dirt from air moving through the unit is electrostatically deposited on internal components; enough build-up can cause short-circuits and diminished peformance. The ozone-discharge plates need to be cleaned monthly, and the inside wiped down at that time. The lint trapscreen on the back also needs to be cleaned (I use hot water in my kitchen sink with the spray-nozzle). I recommend an old toothbrush dipped in household ammonia for scrubbing the plates, and an old sock dampened with ammonia for wiping the inside spaces. The ammonia fumes can be unpleasant, so if you can do this outside or in garage, do so. Also, rinse the plates thoroughly to remove any ammonia residue. Just make sure the discharge plates are COMPLETELY BONE-DRY before putting them back in, otherwise, you risk shorts, and potential damage to the plate. Use the toothbrush without the ammonia (preferably dry) to dust-off the sensor in back that triggers the "service required" light. Iif it's like the ones I've worked-on, it should be connected to another light inside, but I recommend checking your owners manual to help identify the location and description of the sensor.
About once a year, a thorough cleaning (using a brush to get the accumulated gunk out of the nooks and crannies) is recommended). This involves disconnecting the fan leads and (if so-equipped) the needle-point ionier after removing the four screws through the bottome holding the chassis in-place. If you're not comfortable working with wiring and spade-terminals, you may want to use a keyboard vaccuum brush (long-necked tube with a brush on the end available in office-supply stores and the like) to reach in instead.
If this helps, please rate me... thanks!
Jon
Nov 28, 2011 | Alpine Air XL-15 Air Purifier
IonizAir P4620 Air Purifier: R1 is fried. What do I replace it with?...
R1 is a 5 ohm resister. 1/2 watt was used. If it fried go to a higher power rating. It limits the current to the high voltage transformer.
May 05, 2010 | P3 International IonizAir P4620 Air...
Bought used model - should I clean plates inside or on back and how to do it?
The Plates need cleaning regularly with 1/2 ammonia and 1/2 warm water. In a shallow flat-bottomed container, with enough solution to completely cover the plates, let them soak for NO MORE than 10 minutes. Rinse well, then brush both sides with a stiff brush and rinse well again. Shake off the excess water, then thoroughly dry with a blow dryer, before reinstalling. If you e-mail to miller@healthyti.com and ask for cleaning instructions, they will gladly e-mail supplemental instructions (free) beyond what Ecoquest supplies on their website.
Sep 02, 2009 | Ecoquest Living Air Classic Air Purifier
Ionizeair "check" red light is still on after cleaning
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Aug 19, 2009 | P3 International IonizAir P4620 Air...
How do I clean the metal screen? Do I need to replace any filters at any point?
if the metal screen is removable, run under warm water and gently brush with damp rag
if no removable, unplug unit, wipe clean with damp rag
May 29, 2009 | Ecoquest Flair Air Purifier
Cleaning the filter
Yes to get the clean filter light to go off, you have to clean filter, put back in the machine, and hold down the power button for 3 secs to reset it. the clean filter light will go off!
Nov 14, 2007 | Brookstone Pure-Ion (506840) Air Purifier
IonizAir (AR3397) Air Purifier Logo
237 people viewed this question
Top IonizAir Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an IonizAir Air Purifier Expert? Answer questions, earn points and help others
