GE JTP85 Electric Double Oven
Problem for GE JTP85 Electric Double Oven
Microwave will turn on but not heat
By Cookingmom on Nov 26, 2007
My GE JTP55 electirc double oven microwave turns on but does not heat. The oven works fine. Microwave light and all functions can be pressed and will make noise but not heat. Any suggestions?
Same Problem
Jul 21, 2008
-   less than 2 months after recall repair, GE JTP85 micro sounds loud and smokes when turned on-   Guest
Apr 11, 2008
-   I have the same problem. The fuse and the door switch are OK. What can be next possible cause ?-   Murphy28
Feb 12, 2008
-   GE Microwave JTP85BOA turns but does not heat.-   reddy57
Jan 11, 2008
-   Same problem as Cookingmom. I suspect the magnatron. How can you tell if the magnatron is bad?
-   aslamhh
Jan 11, 2008
-   I have-   aslamhh
Solution #1
posted on Apr 27, 2009
Not Rated)
ginko
Rank: Guru  GE Expert
Rating: 89%, 5120 votes
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Was this helpful?
Yes
No
Popular Solutions for GE JTP85 Electric Double Oven
Questions and Unsolved Problems for GE JTP85 Electric Double Oven
Do you recommend GE JTP85 Electric Double Oven?
Answer
Answer
microwave door sticks. if I press and "hold" the door release button, the door will open.... (More)
Answer
Im smelling a burnt smell in microwave The carousel is spinning slow
Answer
I have the same problem. I've just replaced the membrane touch pad for the 4th time. This time, the... (More)
Answer
My GE 27" JKP77WV got very slow reaching even 330 F. It cannot reach 500 F ; I did calibrate... (More)
Answer
I need the wiring diagram for control panel WB27T10297 for GE Profile Built-in Double Wall Oven... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Ovens Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
