Question about Gigabyte Giga-Byte: GA-8VM800M-775 LGA775/P4M800/A&V&L/AGP Motherboard (MOTGB32)
Unit shuts down and restarts for no reason
I have this mobo with celron d 3.33 250 seagate hard drive and 1 gb 3200 ddr 400 ram. I can start up unit just fine but somewhere between 5-10 minutes it starts shutting down and restarting. Tried antivirus , defrag, everything including changing the bios to stop anything that would shut it down and still it stops and restarts. the cpu is running at 67c and sytem is running 57c. Any ideas?
Re: unit shuts down and restarts for no reason
Check all cables ide connectors .the problem may lie in the processor loose hsf or broken pins.if not irregular power supply .
Posted on Nov 27, 2007
0 characters
3 Points
if the memory supports those frequencies, in most cases it would work, now depending if the board is proprietary, like dell or some hp's, then you may run into compatibility issues. you can find this information from the manufactures website.
Oct 16, 2013 | Motherboards
Smoke smell from pc after ram change
yep, your mobo is fried, DDR2 and DDR do not share quite the same pin payout. Toasty Mobo, but on the plus side now you'll be able to buy one that has better driver support.
And kudos for hiring an assistant who shoehorned RAM into a slot it did not fit in and firing it up.
Dec 24, 2009 | VIA ASUS SK8V MB, 8T800/ SATA/ RAID/...
According to motherboard manual (p. 2-9), it can support upto 2GB of DDR400 RAM int total. You can get the manual from
Dec 21, 2009 | MSI K8T Neo-FSR Motherboard
Problem With ddr2 (Upgrade From ddr 512mb 400 to ddr2 1gb 800)
If it works fine with one stick of ram. Then it is the ram that is incompatible. You can try different settings but you may end up that the stick isn't compatible. Hope this helps let me know if you have any other questions.
Thank you,
Nov 05, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Replacing existing DDR RAM
Well this that you can use PC3200 DDR 1GB then those you mentioned above ... and let me tell you there is only bus speed difference between ..
Jun 23, 2009 | MSI 865P Neo (MS-6742-020) Motherboard
Ram capacity
This motherboard supports RAM upto 8 GB but 32 bit Operatin system give support 4 GB. To know more about the mobo follow the link below
Jul 04, 2008 | Intel ASUS P4C800-E Deluxe 875P Socket 478...
Installing new memory
ya cuse old moduel is slower hu drops speed back to 2700 and not 3200 ? corect its in bios settings re auto detect ram set to automatic config itself what brand ram u buy sum fox commm bords very picky on low denstiy and hi density styles ok low beter more compatble 38 bucks 1 gb on ebay ddr 400 i run 3 of those in my gigybyte moby and it loweres my ram spee dto 333mhz not 400 when i use all the slots up cheak your bios settings let me know name brand usally the pp who make it call them tell thenm and ask for time settings to be best with your mobo ok if they have great tech support if not tell me models
Jan 17, 2008 | Foxconn 760GXK8MC-RS Motherboard
Not able to install softwares
What happened with you tried to install the software?
Jan 05, 2008 | ASUS A8V-MX Motherboard
Gigabyte Giga-Byte: GA-8VM800M-775 LGA775/P4M800/A&V&L/AGP Motherboard (MOTGB32) Logo
139 people viewed this question
Top Gigabyte Motherboards Experts
Brian Sullivan
Brian Sullivan
Are you a Gigabyte Motherboard Expert? Answer questions, earn points and help others
