Question about The Computers & Internet
I just installed my wyze cam, but when I go outside to wacth in my phone doesn't turn on in the phone
    Sergeant:
  • 288 Answers
For connection issues, make sure that you have your router given a port forward for your webcam. Otherwise you can't connect it.
You need to know your IP address of the webcam and you need to know your external webcam address.
Log in into your router and go to port forwarding. The webcam wil probably have a stream over port 80. So fill in the IP address of your webcam and with TCP port 80. Then if you log into your phone, you can access it via your external IP address.
Posted on Jan 17, 2019
Tip
Manual of instructions for wacth Nike Chise Wc0045-001
I'm trying o find a manual of instructions for wacth Nike Chise Wc0045-001.<br /> If somebody have it please send me by email <a href="mailto:godoyva@hotmail.com">godoyva@hotmail.com</a><br /> thanks<br /> Valeria
on May 03, 2011 | Nike Mettle Chisel Watch Black WC0045 001...
How can I change the battery of my wacth my wacth is police brand
You have to have the right tools that pry the back or screw the back off good luck.
Jan 05, 2015 | Police Watches
When i click view webcam it says cam not installed or cam is occupied by other user
what you want to do is to try turning off your computer and unplugging the main power cable in the motherboard that is 16 or 18 pin and reconnect it and turn on your pc if that doesn't work try reinstalling your webcam software and make sure that you use the factory settings when you install it or the last thing that you can try is to reinstall your OS and make sure that there are not 2 accounts logged in at the same time...
May 27, 2011 | eMachines Computers & Internet
Install my cam
Plug in the Cam and then put the install disc in the CD Drive. After that follow the instructions.
May 03, 2011 | Computers & Internet
Have webcam in my PC, doesn' t know how to use it, please help
Under programs, there is a dell web cam program,there is also a dell web cam help file,if you install skype (a free web cam communication program) it will automatically turn on and off the web cam as the program starts and exits.there are also other dell web cam programs that will let you adjust ,and take snap shots called web cam console and dell webcam manager
Jan 16, 2011 | Dell Inspiron 1525 Notebook
Schlage deadbolt installed about a month ago. The key will not turn the lock from inside but will from outside. Any suggestions?
my guess is that during installation the inside lock cylinders were 1/2 or a full rotation more in one direction than the outside cylinders. remove it from the door, assemble it and try it without installing it. If it doesn;'t work, take it back. If it's old, oil it. if that doesn't work- toss it- you've spent an hour on a $15 item.
Sep 24, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
I cant wacth youtube.com
jhoeymonteci you didn't say if you have ever been able to watch youtube. I am going to assume that you have Adobe Flash Player installed. What you need to do is to go to the Adobe site and download and run the Flash Player Uninstaller. Then go to youtube and click on a clip. You will be told you need Adobe Flash Player to view the clip. Download it from the options (be sure to uncheck the toolbar option if you don't want it.) After Adobe downloads and installs you should be able to view flash clips again. You MUST use the uninstall to be able to re-install a working player. Hope this helps
Apr 04, 2009 | Acer Computers & Internet
Valve timing
hello
ok to start intsall by putting the proper cams in their proper spots. they should be marked "FR IN" for front intake "FR EX" for front exhaust and so on. the caps should be marked as well. then tighten them down in a crisscross pattern at 15ftlbs. be sure that the cam journals were lubed before install as well. this will prevent siezure. if both cam sprockets were removed, install the front cylinders cam sprockets first. remove the crankshaft timing hole plug on the left side crankcase cover. and the crank bolt access plug as well. turn the crank counter clockwise till the marks FT notch aligns.
install the cam sprockets and cam flanges so that they read as follows. the timing marks FI for intake and FE for exhaust are flush with the valve cover gasket surface outwards opposing. then align the cam bolt holes while lobes are facing upward. you can then turn the crank counterclockwise to install the bolts. then you can remove the cap bolts to install the cam chain guide plate and instll it.
for the rear. turn the crank so that you see the same timing marks as mentioned earlier. with the crank on the FT position. and the cam sprocket marks to the outside flush with the gasket surface.
next turn the crank counter clockwise 3/4 turn or 270 degrees and align the RT mark in the flywheel inspection hole. then you will install the cam sprockets and chain and cam as the same as you did for the front.
i hope this helps. thanks
Mar 19, 2009 | 1999 Honda VTR 1000 F Firestorm
Tensioners
Drain the primary and remove the primary chaincase cover. There are 2 bolts with lockplates and washers thats hold the shoe. Remove them, install the new shoe, reinstall the 2 bolts. The lockplate is installed outside of the washers. Thats it
Sep 28, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Computers & Internet Logo
27 people viewed this question
Top The Computers & Internet Experts
Inky Fingers
Inky Fingers
Fred Sops
Fred Steinberg
Fred Steinberg
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
