Question about Google Computers & Internet
I have a job link 300 and it won’t connect or reset. I press the google assistant button and it gives a demo, that’s all. Is there a way that I can factory reset it?
    Problem Solver:
  • 6 Answers
Depends what device you use ,for reset..
Posted on Jan 12, 2019
  • Ej Edwards
    Ej Edwards Jan 12, 2019
    Typo. I meant JBL Link 300
4 Suggested Answers
kamal1984
  • 1383 Answers
SOURCE: D Link DIR-300 - Connection was Reset - Unable to set up router
press reset button for 10 seconds then all settings are defaults.
you can access your router witrh following link
http://192.168.0.1 or
http://192.168.1.1
Posted on Jul 14, 2009
  • 504 Answers
SOURCE: Husqvarna model 300 sewing machine won't start. Is there a reset button or code?
read service manual download with given link
www.bellanca.us/17-30_Service_Manuel.pdf
Posted on May 19, 2012
extremejojog
  • 64 Answers
SOURCE: i tried to reset the itel it1452 by pressing the power button and volume up as what google says but it still reach the password screen and i can't see any wipe data for factory reset?
Try to find hard reset combination if that model have that.
Posted on Dec 11, 2014
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
How do I make the word "Demo", which is emblazoned across the screen, go away?
Did you do a factory reset? From off pressing power and volume + buttons together till reset screen comes up then select factory reset!
Nov 10, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
I have a store demo 8.9 kindle fire hd. How do i get wipe it and/or root so i can use it as a regular tablet
The Demo Kindle Fire Model Number 3HT7G is completely locked down. It is not possible to remove the Demo, reset the Kindle or Flash new Firmware using a Backup and Restore Utility like Kindle Fire First Aide. The Development Team of Kindle Fire First Aide is working on a procedure to reset these Kindles but the procedure will involve opening the Kindle which Voids the Warranty. Until we develop this procedure you are locked out. Sorry, I wish I had better news. Best regards, Chris Bryant - Prokennexusa at XDA Developers
Dec 08, 2012 | Amazon Kindle Fire HD
I want to configure my router through web,but i ca not connect at 192.168.0.1 web address..
The default IP for the DIR-300 is 192.168.0.1. First, make sure you're entering "http://192.168.0.1" in your browser's address bar. In some browsers, if you try entering just the numbers, it won't work.
If you can't access the setup page at all, that address may have been changed. If this is the case, or you can't log in because you don't remember the username and password, you should reset the router which will restore the factory defaults.Press the recessed rear-panel reset button and hold it in for 10 seconds. Release it and the router will restart. The defualt IP (192.168.0.1) and username and password (both admin) will be restored.
Aug 16, 2011 | D-Link DIR-300 Wireless Router
My dlink 300 is not sending out the wifi signal. when i connect the internet wire directly to my laptop, it works but the wifi does not. Any suggestions how to fix this?
Try reseting the D-Link back to the default settings then configure it again.
Press and hold the RESET button at the back of the router with the power ON untilthe LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Aug 03, 2011 | D-Link DIR-300 Wireless Router
WE HAVE A KODAK ESP-3 AND HAVE PUT IN NEW INK (BLACK) AND IT WON'T PRINT. THE COLOR SHOWS EMPTY BUT IT'S ALSO NEW. ONLY WANT TO PRINT BLACK BUT IT WON'T PRINT EITHER JUST SHOWS LOW INK ETC.
First: you need both ink cartridges for the printer to function properly.
Second: You may have a bad printhead, do the following:
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Contact Kodak:
All-in-One Printer Phone Support Live telephone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight, Eastern Time, 7 days a week. The expected wait time for phone support is 15 minutes.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 27, 2011 | Office Equipment & Supplies
My Archos 101 has a demo version and goes into demo-mode every 5 minutes. Any way I can remove this 'obstacle'?
1. You can press the RESET button by inserting the end of a paper clip into the hole underneath the device (to the left of the USB cable connector).
Note that it won't erase any data, it will just restart the device as if it was a computer.
2. Press the power button as usual to turn on the unit.
Do not press any buttons, the screen will still display the demo mode for about 20 seconds and then it will go back to normal display mode.
Jun 04, 2011 | Computers & Internet
Lost my password for d-link
You can reset the D-Link back to the default settings by power up the D-Link and press and hold the RESET button at the back of the router until all the LEDs flash.
Open a browser and enter the configuration URL
http://192.168.0.1
The default password = blank (just press enter)
Sep 18, 2010 | D-Link DIR-300 Wireless Router
http://192.168.1.1
Jul 14, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Computers & Internet Logo
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Peter Dragonetti
David Payne
David Payne
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
