Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
Power Save Mode Problem
After about 10 minutes, my Dell 2405FPW goes into power save mode and will not come back out of it without turning the computer off and then back on. It does not respond to hitting a button on the keyboard or moving the mouse. I set all the power settings on the computer to always on so the pc will not power down or hibernate. This is a definite monitor issue. Suggestions? This is extremely frustrating.
  • Bitz13 Nov 26, 2007
    There is the ACPI fixed feature button, ACPI power button, and Microsoft ACPI complient system, it says all drivers are up to date. The only option is to uninstall them but I don't think I can do that can I?
  • 20 Answers
Under bios menu look for ACPI function and disable it. Should help same under device manager.
Posted on Nov 26, 2007
  • Marat Ochakovskiy Nov 26, 2007
    also try to obtain most recent drivers
Won't go into sleep mode
Which operating system ?
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work.
This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation.
Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money!
Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow.
The Shut Down menu appears.
Point at "Sleep" and click on this option.
Your Windows 7 computer goes into sleep mode.
Wake your computer from sleep mode by jiggling the mouse.
There may be a delay of a few seconds before your hardware powers on.
All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode.
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time.
Click "Start" and select "Control Panel." Click "System and Security."
Click "Power Options."
A menu opens.
Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode.
If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Your Computer in sleep mode
First, save all of your work. Information in computer memory is not saved while your computer is on standby.
From the Start menu, select Settings, then Control Panel, then Power Management.
Click Standby Beside When I Push the Power Button.
Push the Power button.
Automatically Putting Your Computer on Standby
Save all work before leaving your computer.
From the Start menu, select Settings, then Control Panel.
Double-click Power Management.
Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks.
Click OK. Your computer will go on standby according to the schedule you have entered.
Putting Your Computer in Hibernation
Double-click Power Settings.
Click on the Advanced tab.
At the When I Push the Power Button On My Computer screen, click Hibernate.
Click the Power button.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Dell Inspiron 545 wont come out of power save mode - when switch it on it tries to start up but then goes into power save mode this then continues switching between power save and starting up until i
Do a full reset. Press power button down until computer shuts down, this will take more than 5 seconds. After that you can perform clean boot.
Aug 18, 2012 | Dell Computers & Internet
My desktop monitor direct go in power save please solve it as soon as possible its urgent
power save mode indicates no input signal. Check the input signal with a known good monitor. if the signal is good then dell monitor is faulty. Power cycle (unplug the power then plug it back in) the monitor to reset to factory and if it still goes directly into power save mode the unit is faulty.
May 01, 2011 | Dell E1709W Monitor
E172FP (Black) 17 in. Flat Panel LCD Monitor: Dell monitor problem, its the power save mode agai...
First, try it on another PC, check or try another VGA cable, if it still does not work then you need to open it up. Dell monitors are known to have bad solder connections, bad caps. See my photo albums of failed Dell monitors to get some idea what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Replacement bd:
May 18, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Dell screen (1901FP) won't come out of power saver mode
hold down the Fn and F8 keys, and it worked fine for me. or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep
Sep 24, 2009 | Dell 1901FPt 19" TFT LCD Flat Panel...
Dell Ultrasharp 24IN FP monitor power saves and does not recover.
disable it from going to power save just turn it off when not in use. your monitor could be having issues with its power supply.
Feb 17, 2018 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
E153fp goes dark into power save mode after Windows start up
may be your power saving option have small time .
check in control panel power option check power shemes.set it to 20 minutes.
Nov 27, 2008 | Dell E153FP 15" LCD Monitor
My screen has gone black
try to reseat the vga cable of the monitor,reseat at the back of the computer and on the monitor,if the cable is disconnected,make sure that you can see the power on self test with different colors in it,if you cant see it then your monitor went bad,try to connect another monitor to your computer,see what will happen,try using other cables as well
Jul 05, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell 17" flat screen monitor
When they stay in power save mode the logic board is usally the problem. Cneck out they sell all the parts for that unit.
Dec 10, 2007 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
532 people viewed this question
Alun Cox
