Question about Amana Refrigerators
Amana AFD2535FES now 12 years old is running too cold in the refrigerator. Freezing fruits and veggies. Setting turned down from 5 to 4 and still too cold
    Top Expert:
  • Amana Master
  • 49,855 Answers
Temperature controller failure
Posted on Jan 12, 2019
  • 1218 Answers
SOURCE: I have an Amana BRF20V1S refrig w/bottom freezer.
Good day,
Tricky problem.
The fresh food compartment gets it's cooling from the freezer.
When running zero degree air is blown up the back wall and out to the fresh food compartment thru a modulating thermostat.
This modulating tstat is continuously opening and closing .
I have seen many of these where the spring that tries to keep the flap on this device closed, has popped off.
If you can find the spring, it usually can be reinstalled, if not, you have to replace the whole control.
If that control is working O.K. another problem is at play.
During cooler weather, and light usage, the machine tends to stay off longer.
This causes the air in the machine to stratify. Warmer air rising, colder air falling. Thus, the warmer air reaches the modulator at the top of the machine, and throttles it wide open.
On the next running cycle, it allows a large volume of near zero degree air to enter the fresh food compartment.
Here are two possible solutions. The first cannot be verified.
A user claims that the return air vents behind the crispers got blocked by various items from food handling, and prevented the cold air at the bottom from returning to the freezer.
Your using a foam at the bottom would only make the matter worse.
The second option, would be to replace the modulating thermostat, and test for results. It's a pricey part.
Hopes this gets you some results..
Jack....
Posted on Dec 10, 2009
  • 28 Answers
SOURCE: MY Amana is 12 years old. My vegetables and other
most likely needs new temp thermostat
Posted on Mar 03, 2010
BMT60
  • 126 Answers
SOURCE: My GE Profile Performer refrigerator is freezing fruits and veget
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: Amana bottom freezer - food is freezing in refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
SOURCE: Amana AFI2538AES The refrigerator portion keeps
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Posted on Apr 30, 2011
Amana upright commercial freezer not freezing
did you lay it down during transport .if so it needs to stand unplugged for 24 hours .the oil will have run out of the compressor
Sep 26, 2016 | Amana Refrigerators
How do I troubleshoot a cold, but not freezing, freezer (Amana ARS2664BW)?
there should be refregerant refill by an expert professional
Jun 15, 2014 | Amana Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Our Amana bottom freezer refrigerator is too cold in the refrigerator portion. It keeps freezing all the fruits and vegetables even though the temperature is set on the warmest setting in both the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 11, 2011 | Amana ABB1927DE Bottom Freezer...
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Fans and compressor are running but is not cooling. 5 years old. evaporator coils are not getting cold
Good day,
If both fans are running as well as the compressor, then it is one of these possibilities. Either the system has leaked all of the refrigerant out, or the system has an internal restriction, or lastly the compressor has failed internally with a bad valve ect.
All of the above items will require the attention of a qualified tech who has the proper tools and equipment to determine your problem.
Note: If the machine is under 5 years of age, then the factory warranty would be in effect. You would have to call the selling or servicing dealer to have it corrected, but it would be free.
Oct 16, 2010 | Amana AFD2535FES Stainless Steel Bottom...
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Veggies freeze up in the compartment meant for them
1 is the warmest setting, 7 is the coldest.
No answer for your veggies freezing.
Jan 09, 2009 | Amana ABB1927DE Bottom Freezer...
Frozen food in refrigerator
turn your freezer up all the way and your refrigerator down a little. this will block some of the airflow going to the refrigerator.
Jul 05, 2008 | Amana Refrigerators
Refrigerators Logo
29 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
