Question about Lexmark Office Equipment & Supplies
Lexmark c544dn, a film quality piece was stuck like a paper jam, what is broken and can it be fixed?
pastorm
  • 98 Answers
SOURCE: Paper Jam
The fuser unit has a pape sensor. If, for some reason, the sensor is stuck, the printer will read a paper jam. Open the rear door and inspect the paper sensor located in the fuser assembly. See if it came out of it's original position or if there is something blocking it from moving freely. Good luck.
Posted on Aug 23, 2007
  • 163 Answers
SOURCE: paper jam, and check film error messages
dear sir the film sensing sensor and paper path sensors are abnormal or dusty pleaz check them
Posted on Sep 21, 2007
SOURCE: PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Posted on Jul 22, 2008
  • 684 Answers
SOURCE: Lexmark X4650 ink jet printer has paper jam
Please follow these steps to set your printer to defaults:
1. Please make sure your printer is set in Copy Mode.
2. Press the "setup" button, you will find "Maintenance" displayed.
3. Use your arrow keys to locate "Set Defaults" and press "OK".
4. Press the arrow key to find "Use Factory" and press "OK"
This process would reset your printer to Factory defaults.
Posted on Apr 29, 2009
thunderbo611
  • 75 Answers
SOURCE: Lexmark T630 paper jam 238 it says check duplex.
in the back
Posted on Jan 26, 2010
I keep getting paper jam and load letter paper on my C544dn but yther eis no paper jam and there is a good amount of paper in the printer.
Take a look DEEP inside your printer. Sometimes all it takes is a tiny piece of paper to indicate a jam. Remove your printer cartridge(s), pull out your paper tray, open covers, etc. It is in there somewhere.
Nov 29, 2017 | The Office Equipment & Supplies
What does 200.04 jam error indicate?
Did you look the jam code up in the operators manual? might try going to the Lexmark web site and look up your model mite have a updated firmware that will fix that problem, also are you using paper that is authorized to be used with that machine? look up the spec in the op manual or web site, check the weight of the paper the paper draw rollers may be dirty clean with a small amount of soap and water.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 17, 2015 | Lexmark C544dn Laser Printer
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Its an Error Related to a Paper Jam on the Paper Roll Tray!!!!!
Please Check the Inside of the Printer if there are any Bits of Paper which are stuck on it!!! That would cause this Error Message to Appear!!!!
Good Luck!!!!
Feb 21, 2013 | Lexmark C544dn Laser Printer
Our lexmark c544dn has a paper jam but when I open the front cover I do not see one. What else should I do?
Pull back the fuser cover ( black upper area) and look for the jam beneath the black roller with paper sticking up - to pull it out
Aug 05, 2011 | Lexmark C544dn Laser Printer
Inkjet fabric paper stuck in lexmark c 544 dn against platinum
Use only recommended media for laser printers. To get more details about the different media supported you can refer to your user's manual or try the link below. http://bitly.com/mP1hB3
Aug 02, 2011 | Lexmark C544dn Laser Printer
I have an error code E000007-0000 after a paper jam in my Canon ir3300. I wish to get a solution on this
these error stands for problem with the reading of fixing film in fixing assy.
If you had a paper jam, its possible that piece of paper stuck-ed on reading path of sensor or the fixing film is worn out and it needs to be changed.
To check for paper leftovers, open the left side way door and check the fixing unit for leftovers of paper.
Hope that helps!
Apr 26, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Our Sharp ARC150 seems to have a static problem. It keeps misfeeding and when I open it up to get the paper out it's always at the same place where the paper is stuck to the roll of film that moves it....
In a copier static is usually a good thing. The "roll of film" you are refering to is the transfer belt...it should be static !! and not cleaned with anti-static cleaner. The belt uses the static to hold the paper in place and transport it. Putting any type of solution on the belt will probably damage it and cause further issues - especially copy quality.
It could be that the belt is not moving at the correct speed due to maybe 1)worn/broken drive gears 2)drag caused by the cleaning blade. Or there could be a sensor that is miss-reading the timing of the paper reaching a certain point and then causes a jam. Is the paper in the trays set correctly to match the paper sizes and orientation it shows on the screen? Does it give you a jam code on the display? Does it jam from all the paper trays?
Jan 14, 2010 | Sharp AR-C150 Copier
Printer problem
even a very small piece of paper (A small piece torn off a jammed sheet) can cause the sensor arm to stick in place giving a false paper jam. Double check the entire paper path (what is visible) using a flashlight.
Also, check for broken "flag" sensors. Basically a flag sensor is a small piece of plastic that is pushed out of the way when the paper is traveling through the unit. If one of these flags is broken it may display a paper jam error as well (The flag after paper travels through will drop back into the paper path.) If this is broken it will not trigger the sensor and thus the error condition exists..
Most likely you have a small piece of paper stuck inside the paper path somewhere.
Do not, I repeat do not use any sharp or pointed metal objects to remove any small paper from within the fuser unit, the fuser covers are very delicate and such poking and prodding will likely damage the fuser covers, causing bad print quality or drastically decrease the fuser life (a small tear will quickly render the fuser useless).
Hope this helps!
Aug 31, 2009 | HP Office Equipment & Supplies
Paper is getting jammed hence not printing
Sounds like somthing is caught in the left hand side try looking in it with a flashlight and see if you can see somthing stuck like a twistie tie/sticky label/ staple / sticky tape.... If its in far try using a ruler or a few pieces of paper stacked together to dislodge it.
May 06, 2009 | Lexmark Z2420 Printer
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
