Question about Canon PIXMA Office Equipment & Supplies
Canon pixma mg5220 not feeding paper through to output tray. I can hear turning but there is no paper coming through
SOURCE: Canon Pixma MP160 paper will not feed
try the feed button which is usually on the front of the machine. press once
Posted on May 22, 2008
josephmanoj
  • 71 Answers
SOURCE: canon pixma mp110 wont feed
Hello Dear,
There must be something obstructing the Auto Sheet Feed Assembly, you need to clean the paper path, use a vacuum cleaner or look deep into it if you can find something there, if the problem persists you should take your printer to the service center and get it serviced.
Warm Regards,
Manoj Joseph
+91 9352008418
Posted on Jun 17, 2008
SOURCE: mp600 pixma printer
I'm not sure if you've already checked this, but this was my issue. I, too, would try to print something and it would make a great deal of clunking noise but would then say that there was no paper and told me to load some. I went to the Canon site and before I actually went through the process of cleaning the print roller, I checked the feed switch button on the display panel. It's right below the ON/OFF button and, what do you know, it was set to feed from a paper cassette instead of the back loading tray. I pushed the button and it's now printing fine. I'm sure we must have accidentally hit the button when we were trying to turn the printer on or off quickly. Hope this does the trick! It's always nice when it's something easily fixed!
Posted on Sep 07, 2008
pineworks
  • 4293 Answers
SOURCE: canon pixma ip1980 service error 6000
Hi there
You can try this may help you.
These are the steps:
1. Turn On iP1980
2. Push and Hold Resume button about 2 minutes
3. Release Resume button
4. Printer back to normal again
To get Permanent , follow the steps here :
Manual Resetter canon Pixma iP1980/1900 Download
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 07, 2010
watsonhellas
  • 774 Answers
SOURCE: how to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Posted on Aug 27, 2012
What does E02 mean
PDF]canon printer error code e31.pdf - WordPress.com
https://maitioprolur.files.wordpress.com/.../canon-printer-error-code-e31....
... on Canon. Printer MP287 : E02 E31 Cause : The printer is not connected to the computer ( the printer is ... Canon Pixma MP287 All in One Printer List of Error Codes There ... Cartridge: Canon E31 Toner CANON Printer + Copier + Scanner -.
Aug 26, 2015 | Canon PIXMA Office Equipment & Supplies
My Canon printer MG5220 printer says that there is a paper output slot - paper jam
It means one of the sensors did not send a movement of paper, when needed. Could be a sheet of paper, a scrap of paper, but sometimes something just dropped into the printer, like a paper clip. So carefully look (with a torch or other bright light) if you can find anything where the paper should go. also open and close the printer as if you replace cartridges an see if you can find anything that does not belong in a printer.
If you can't find a thing and when you unplugged the printer from the mains for a few seconds. and then switched it on and the error keeps coming back, contact a service centre or buy a new printer.
Jan 13, 2015 | Canon Pixma Mg5220 Wireless All-in-one...
Paper jammed in output slot but not
you might check that the sensor output is not broken. Also see if the sensor does not have a piece of paper.
Apr 13, 2014 | Canon Pixma MG5220 InkJet Printer
Canon PIXMA MX880 will not pull paper from front tray when copying. The MX880 will pull paper from the front tray when printing from the computer and the rear tray when printing envelopes. I only have a...
The reason for that is the front is the paper output tray, the rear tray is where you load the paper. Anything you print, copy, or scanned (to print) will come out the output tray (in front) and will pull paper from the rear tray.
Nov 03, 2013 | Canon PIXMA MX860 All-In-One InkJet...
What does close the feeder tray mean
The Canon PIXMA iP4000 InkJet Printer has two paper sources for printing. Likely the top feeder tray is not completely closed (it is possible you do not have the printer set up to feed from both which may cause the error).
See the Quick Start Guide and the Picture Below:
Mar 06, 2013 | Canon PIXMA iP4000 InkJet Photo Printer
How to print on postcard size paper?
Most domestic printers have a variable paper tray in which you can adjust the size manually, simply put the paper to the correct corner and print.
Oct 18, 2012 | Canon Pixma Mg5220 Wireless All-in-one...
How to load photo paper in paper tray canon mg5220
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
How to use the back paper tray for Canon Pixma MG5220 Printer
To use the Rear Tray for your current print job (this should last until you close Word) :
Use Ctrl+P to open the printer window. Click on the Properties button. On the Quick Setup tab find the Paper Source drop-down and select Rear Tray. Click the OK button.
To permanently set the Rear Tray as the default:
Click the Windows Start button, then click Control Panel and select Printer. In the popup window right click on your printer icon and select Properties. On the General tab, click the Printing Preferences button. On the Quick Setup tab find the Paper Source drop-down and select Rear Tray. Click the Apply button, then the OK button.
Apr 01, 2012 | Canon Pixma MG5220 InkJet Printer
I have a Pixma MG5220 printer I bought in January. When we try to load the paper, a screen comes up and says No paper. we have hit the OK button as instructed.
There are two paper sources on this unit, One is a cassette tray, a drawer in the lower front. You may have that source chosen, and no paper in it. I recommend using that tray for your regular plain paper.
Apr 09, 2011 | Canon Pixma MG5220 InkJet Printer
Canon Pixma MX850 says it's out of paper when there is paper
The feed switch changes the paper feed from rear feed to tray feed (paper tray is under the output bin). If you have paper in the rear feed, the green light should be on top of the printer icon left of the feed switch. If you have paper in the tray, the light should be on the bottom of the printer icon.
Apr 14, 2009 | Canon PIXMA MX850 multifunction InkJet...
Clive
Clive
old marine
old marine
