Question about The Office Equipment & Supplies
My Pixma 780 has the In use/memory light flashing and I can not print. My laptop says the printer is offline. I have docs in the memory and the USB cord is plugged into the correct port.
    Top Expert:
  • The Master
  • 49,783 Answers
The print queue is jammed.
Posted on Jan 12, 2019
how whee
  • 8 Answers
SOURCE: D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Posted on Feb 21, 2008
SOURCE: canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Posted on Mar 12, 2008
welcomejee
  • 10594 Answers
SOURCE: cannon pixma 780
is your printer under warranty? If yes, ask warranty cover please.
Posted on Sep 24, 2008
SOURCE: Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Posted on Jul 10, 2009
torresfvr
  • 69 Answers
SOURCE: DLINK DP-300U. Desktop shows printer offline, Laptop prints OK.
First thing.. plug printer directly into PC.. does it work? .. if so its is a port setting. If now it is the device config on PC
If Port Setting Issues.. are you going through any other devices on the network or is you firewall blocking the IP.
If device Config issue check to see it is setup up as an IP Port not a normal local port
Posted on Jul 24, 2009
How to print memory
hi there :
Press Menu , then choose - Fax Settings ,choose Memory Reference , there are 3 opcions : > Print Memory List > Print Doc. > Delete Doc.
I hope this information will help you.
Dec 10, 2011 | Canon PIXMA MX310 All-In-One Printer
As long as i have my usb cable hooked up to my printer and laptop it works but when i disconnect the cord its offline.what should i do?
It may not be configured to the correct port.The port selected could have been the USB port that's why when you disconnect the USB cable printer goes offline and would not print wireless. Follow the steps below if you are using a WINDOWS computer: For windows XP :
  • Click on start then go to printers and faxes.
  • right-click on the default printer canon pixma mx340 series
  • go down to properties
  • click the ports tab
  • check to see which box is checked.If the usb port box is checked,that answers the reason why printer goes offline and would not print wireless when USB cable is disconnected.
  • In the list of ports ,look for tcp/ip with the correct ip (192 number) address of the computer.
  • when you find it,tick the box,click on apply then ok.
  • if you do not see it anywhere on the list ,you need install the software.
For win vista
  • click on start,in the search box key in printer then hit enter on the keyboard
For win 7
  • click on start,in the search box put in devices and printers and hit enter
  • click on printer properties
Let me know if you need assistance in configuring wireless connection and installation.
Jul 17, 2011 | Canon PIXMA MX340 Wireless Office...
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Computer says Orinter is Offline but is connected. Has the Fax button highlighted. Only have Copy, Fax, Scan, Memory Card to select from, which one should be highlighted for printing from connected PC
In order to print from PC you should choose COPY function. To check the connection between PC and your printer perform these steps:
  • Right click on printer driver name (Canon PIXMA MX 850 in this case)
  • Choose Properties
  • Click on Maintenance tab
  • Click View Printer Status: the status should ONLINE in order to print or scan
If still Offline,please recheck USB cable,reinstal it,or compare with another cable.
Source: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon Pixma MP150 offline - won't print from computer
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-25
Aug 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cannon pixma 780
Sep 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer offline
Go into control panel/ printers and faxes and see if you have more than one copy of the printer in there. (it may have installed more than once) make the last copy of the 780 the default printer then it should be ok.
Aug 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
21 people viewed this question
Top The Office Equipment & Supplies Experts
Scott Yeoman
vince
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
