Question about Blaupunkt Televison & Video
My Blaupunkt TV just turns off then turns on to a blue screen then turns off again and repeats this no matter what I do with the remote
  • 927 Answers
SOURCE: mitsubishi ws65613 no picture or sound, blue screen only
Good day, Bgchzy;
This model is known for the tubes leaking fluid, glucose, on the PCB. Check the front of the chassis for said fluid, it may be only a drop, so look closely.
To fix, after TV has no power, try cleaning the board with cleaner and brush, let dry. I suspect this because of multi unrelated problems.
Posted on Jul 17, 2008
SOURCE: Tv turns on and off continually
The power supply is bad and must be replaced.
Depending on the TV and what your local repair shops charge, it might be cheaper to replace the TV. This same thing happened to me. I could replace the TV for just a little more than the cost of fixing it! I'm replacing the TV.
I'm sorry that I couldn't give you better news.
Roger
Posted on Jan 03, 2009
  • 718 Answers
SOURCE: TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Posted on Feb 24, 2009
  • 1030 Answers
SOURCE: tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Posted on Mar 18, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Phillips Magnavox constant blue screen
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Feb 20, 2010
Remote control code required for virgin TiVo & 50 inch blaupunkt TV combo
I have just managed to do this. I cannot tell you the code as I had to do it manually, but this is how I did it.
point the remote away from the TiVo and hold down the clear button and the to button until the free light flashed twice.
type in the code 0999 and the light will flash again. Then point the remote at the to and press and hold the channel up button. You will now scroll throw all the codes.
it will take about a minute but eventually the to will go off. When this happens release the channel up button and hold down the green on button to try turn the tv on with the TiVo remote.
if it comes on press ok and this will store the code. If it doesn't come on, use the blaupunkt to remote to turn the tv back on and then keep holding down the channel up button to scroll through more codes. When the to goes off again release the channel up button and try turn it on with the TiVo remote. If it works this time store the code by pressing ok
for me it took two attempts to turn the to on but eventually it worked on the second code
Nov 29, 2014 | Blaupunkt Car Audio & Video
How I can take off Random play from bus blaupunkt dvd-player. It shows (Random) on left side on screen when I put DVD in and movie jumps every few minutes. Very bad to watch movies, cause have to find...
There should be a DVD Repeat modes or "Repeat/Repeat Modes" button on your remote. Press that until it's back to "ALL" and it should play things properly again for you.
Aug 27, 2011 | Blaupunkt DVD-ME1 DVD/CD/MP3 PLAYER Car...
Switch TV on then a blank red screen appear then a green and then a blue which then just repeats that sequence of colours every second. The remote control packed up working some month before. - 2 year old...
turn TV on, let the Tv cycle through the three colours, then using the remote press the menu button followed by the standby button. press standby button again and it all comes up working.
andy
Sep 20, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
What does the Blue wire labeled "System Remote (turn on)" do for the IVDM-7002 unit & where should it hook up to ?
remote turn on for an additional screen, amplifier, eq ect...turns something else on when you turn on the unit.
Mar 02, 2010 | Blaupunkt Chicago IVDM-7002 Car DVD Player
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
My sky remote just newly stopped working, It still works on the tv but when i press tvguide it puts the tv to ch 1 and thats it. Why wont the tvguide work
first of all I would like you to press the blue sky button on the top of your remote. Now press you tv guide button. If this has sorted it Great if not read on!!
what I am going to talk you through now is resetting your remote:
TV
RED + SELECT (flashes twice)
999
now press the blue sky button at the top of your remote now try the tv guide button. this should work no problem now.
now to the small matter of tuning your remote back in to work your volume etc
please follow the steps below:
TV
RED + SELECT
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Jun 05, 2009 | LG 37LG30 37 in. LCD HDTV
Programming the jensen jr400 universal remote
1) Turn on the Proton TV;
2) Press the "TV" button on the JR400;
3) After releasing the button, the red LED indicator should blink twice;
4) Press and hold the SETUP button until the LED blinks twice;
5) Release;
6) Enter 9-9-1 on the numeric pad. Red LED blinks twice;
7) Press POWER;
8) If TV doesn't turn off, press TV again;
9) Repeat #4, #5, #6, and #7. If TV doesn't turn off, go back to #4, until the TV responds.
10) Go on to the next device, i.e. DVD, VCR, etc.
Feb 17, 2008 | Jensen JR400 Remote Control
Televison & Video Logo
21 people viewed this question
Top Blaupunkt Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
donny ardalando
donny ardalando
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
