I still have not found solutions to my HP1040 fax. It will not print anything. New cartridge went through all verification steps. nothing
checkitright
  • 1362 Answers
SOURCE: the fax will not print anything
2 possibilities
1- you did not remove the plastic film on the cartridge
2- the printhead has dried up
Posted on Dec 06, 2007
  • 12 Answers
SOURCE: black cartridge not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Posted on Feb 02, 2008
SOURCE: Samsung SF560.
make sure you have the correct cartridge as the SF560 & SF560R use different cartridges
Posted on Apr 30, 2008
  • 96 Answers
SOURCE: Kodak EASYSHARE 5500 will not print with black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Posted on Aug 19, 2008
debroy
  • 174 Answers
SOURCE: Canon MP 210 gives E5 error and will not print.
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.Make sure the unit is connected directly to the
walljack.
Posted on Nov 27, 2008
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
How do I align the cartridge after I replace it. The fax printed out a sheet and the lines are not straight. I went to tools...to align cartridge and then I am not sure how to adjust the lines
Follow below steps to complete alignment.
  • With the Cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place.
  • Close the cartridge compartment cover and control panel.
  • Press the Start/Enter button.
  • On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old
NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
  • An alignment page will print and 06 [01-11] will show on the display
  • Look at the alignment page and select the number under the straightest line, and then press that number on the keypad and then press Start/Enter .
Oct 17, 2010 | HP 1040 Plain Paper Inkjet Fax
Fax will not print after installation of new cartridge
Look at your NEW print cartridge again, very carefully. I'll bet there's another piece of tape on the bottom of it. That's what happened to me.
Dec 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
New cartridge; now won't print any document, fax or copy
It is not impossible to get a brand new bad ink cartridge. I've seen lots of bad ones.
Oct 04, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Nothing there
Did you try cleaning the print cartridge nozzles.
Press Function once and up arrow 2 times
Press the right arrow once and the up arrow once
Press Start/Memory button
It will print a test parttern page
Once you insert the new cartridge did the machine recognize the new cartridge? You had to press 1 for new
When 1 is selected you will get a prompt New Cart: OK?
OK press start.
If you selected NEW the display will show the alternating messages at right. Align Cartridge----1 Print 2 Set
Press 1 to print an alignment page
Hopefully, it will printed. Let me know one way or the other.
Mar 27, 2008 | Sharp INKJET FAX UX-A1000
Machine not printing
try to go a setup and option clean the cartridge
Nov 21, 2007 | HP 1040 Plain Paper Inkjet Fax
Cannot receive faxes or do copies
If you still have your old cartridge reinstall it that will tell you if it is the cartridge or not. If you still have the problem,it could be the encoder.
Oct 23, 2007 | Office Equipment & Supplies
26 people viewed this question
k24674
Marvin
Marvin
