Question about The Office Equipment & Supplies
Where is the transfer cleaning assembly in a CLC 1180?
  • 168 Answers
SOURCE: canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
Posted on Dec 29, 2008
  • 168 Answers
SOURCE: canon clc 1180 error code 071-0007
k you may have several problems you may take some canned air and blow out the connectors on the tx unit and the inside frame particularly the connectors on the lower right rear frame wall .. when you pull out the tx unit you may also want to turn the two cam gears on the lower left rear frame all the way clockwise then slide unit in
Posted on Jan 10, 2009
SOURCE: looking for canon clc 1180/1160
switch power off and on
Posted on Jul 24, 2009
  • 153 Answers
SOURCE: E020 Error in CLC 1180 Copier
you have a drum/developer related error
Posted on Sep 28, 2009
  • 19 Answers
SOURCE: my machine clc 1180 is displaying a error code
add function 2-8 add function ,copier, function,clear ,error,ok.this is caused by clogged oil tube in the fuser
Posted on Nov 10, 2009
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
E073 0003
hello have a look in side the unit to see if you have any paper no mater how small stuck at the back of the transfer unit,and the transfer drum,if not try cleaning the connections on the back of the transfer unit.also check for a broken switch.
maybe just a good clean may do the trick.
hope this helps
Nov 14, 2012 | Canon CLC 1180 Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
Canon CLC 1180 Copier Error Code: E071 0007
E071 / E072 / E073
Transfer Frame Connector
Poor Contact due to toner scattering around Transfer Connector
Replace Connector FG6 0948
TD Cleaner assy
Motor M8 being overloaded. Drive shaft from motor goes through long plastic bearings these were getting clogged with toner and oil
clean drive shafts
Transfer driver PCB
Static discharge onto transfer driver from peeling off old TD sheet too fast
Replace Transfer Driver PCB (FG6 - 2579) Remove old TD sheet SLOWLY to prevent problem.
Oct 21, 2011 | Canon CLC 1180 Copier
I have this error codecode e000 and 0105 under when i turn on my Canon CLC 1180. where was the fuser user in the CLC? How can i check it?
I think the 1180 is close to the 1120 copier I know. The error code is indicating an upper heater open circuit. The fuser is the very left item when the main drawer is pulled opened to remove a paper jam. There are two handle grips front and rear to remove the assembly. You have to check continuity of the heat lamp, fuses, etc.
Jun 13, 2011 | Canon CLC 1180 Copier
What does e073 0003 error mean on canon 1180
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck.
Courtesy of
andzulisv.
-David.
Nov 03, 2010 | Canon CLC 1180 Copier
Canon clc 1180 error code 073-0003
Dec 28, 2008 | Canon CLC 1150 Color Copier
Error E079 Am using in canon 1180 Printer
E079 is the transfer lift clutch unit int the rear of the copier. You have to remove the unit and look for a broken cam & or pin that goes in the cam and clean both sensors and flags in that unit and make sure it is sping freely. The unit ingages the transfer cleaning unit. Good Luck.
Nov 06, 2008 | Canon CLC 1120 Color Copier
23 people viewed this question
Top The Office Equipment & Supplies Experts
Scott Yeoman
vince
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
