Question about Pocket Watch Watches
How to wind up majesti pocket watch - Pocket Watch Watches
escapement
  • 2338 Answers
SOURCE: trying to figure out how to adjust time
You have broken or displaced setting lever in your pocket watch.
That's why it is not possible to set the time. No matter in what position the winder is, the setting gear are not engaged from the clutch wheel and the time adjustment can not be done. At the same time the crown wheel still engaged in any position and this is why it still winding in both positions.
As repairs of this can be done only by skilled man, go and see your nearest watchmaker and ask for help.
It is understandable that I can not execute repairs over the net, so, rate it as if I did it, please.
Posted on Mar 14, 2009
cmcduncand
  • 714 Answers
SOURCE: watch is fully wind up but doesn't run?
Several solutions:
Needs cleaning is the best possible reason.
Broken balance due to being dropped is second.
r/
David
Posted on Jan 22, 2010
cmcduncand
  • 714 Answers
SOURCE: Elgin 18s pocket watch (1908). Will not wind,
Sounds like a broken main spring.
This is a fairly easy fix and may also be due for a cleaning and service.
Find a local repairman in your area.
http://www.nawcc.org/business-directory/
Hope this tip helps
R/
David
Posted on Feb 16, 2010
cmcduncand
  • 714 Answers
SOURCE: I have some pocket watches I got a few years back
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Posted on Mar 15, 2010
  • 172 Answers
SOURCE: How do I set the
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
Posted on May 29, 2011
I have a remington pocket watch from my great great grandfather and I don't know what battery it takes please help.
If its that old, it may not use a battery. Older watches usually use a wind up knob. Yours is on top, try winding it clockwise. You should hear some clicks if its working. good luck!
May 03, 2017 | Pocket Watch Watches
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
May 27, 2011 | Watches
How do i wind an old seth thomas pocket watch? mfg. 1894, montgomery ward model
mcdevito75 here, I believe you"ll need a special winding key to wind your Seth Thomas Clock, Best Bet, look for a small watch repair shop in your area, they may be able to order a key for you, have all info regarding the clock with you. Winding keys may also be on ebay under Vintage Clocks/watches.
Jul 12, 2010 | Watches
Watch is fully wind up but doesn't run?
Several solutions:
r/
David
Dec 29, 2009 | Sterling J3E Hamilton Antique Pocket Watch
2003 deer pocket watch Al Agnew is it wind up or Battery
Often with battery powered watches the word "Quartz" will be written on the dial. In the abscent of that you can look at the mechanism inside (typically by removing the case back).
Alternately (this may not be an absolute confirmation) with the winder in neutral position i.e. pressed all the way in, turn the crown (winding button) and if it spins freely it's probably quartz. Because unless it's broken most mechanical watches click as the watch is
wound up (except some automatics which cant be crown wound).
Plus if it's working and left unworn for a few days yet continues to run it's probably quartz.
Please rate this solution.
Jul 26, 2009 | Al Agnew Al Ag 3 Piece Pocket Watch...
My Fossil VT2657 no longer works. I can see no physical damage, but it hasn't been used in years. I'm not even 100% sure how to wind it, but after quite a bit of winding in both directions it still...
it has a battrey or and atomatic winding gear. watch makers a stoped self winding watches due to people over windinfg and braking the watch. check battery it might be dead. or just shake the watch back and forth untill it starts again
Jul 12, 2009 | Fossil VT2657 Pocket Watch
My watch has stopped working
mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
Mar 19, 2009 | Colibri Mechanical Collection Pocket...
Watches Logo
24 people viewed this question
Top Pocket Watch Watches Experts
Marvin
Marvin
Harrie
Andrew Taylor
Andrew Taylor
Are you a Pocket Watch Watch Expert? Answer questions, earn points and help others
