SOURCE: blue screen-tv doesnt recognize dvd player
Hello crawf and Saffyrre,
I have seen this issue before, and I have good news and bad news. The good news is the problem is caused by an electronic bypass circuit, The circuit is between the AV derived from the RF input connector (for cable TV and off air TV) and the AV derived from the DVD player Audio Video input jacks. Hence the problem of being able to plug the DVD into other TVs and it works. Now my question to each of you is; Does the TV work on off air and or Cable TV.
This might range from a cold solder joint on the circuit board, to a component actually going bad. I would suggest taking the set to a qualified TV repair shop and getting an estimate. If the cost is right have it repaired, if the cost is not right replace the TV with a new one.
If you do decide to replace the TV could you both send the bad TVs, so as I could figure out what is causing this problem, design a fix for it and then provide an actual online solution to this problem because this is happening way to much for it not to be a systemic problem with all of these Hello Kitty TV sets.
Thank you both,
I hope this helps,
Shuttle83
SOURCE: a dvd is stuck in the dvd player of my polaroid
if you will look under the drive where you put the dvd in there is a little pin hole push a small paperclip in there and the dvd will pop out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
SOURCE: program comcast remote to dvd player
THIS SITE HAS MANY CODES FOR MANY REMOTES. IF IT DOESN'T HAVE YOURS PLEASE LET ME KNOW AND WE WILL FIND IT A DIFFRENT WAY.
http://www.xdiv.com/remotes/
IF THIS DOES HELP CAN YOU PLEASE RATE ME.
( I GUESS IT IS IMPORTANT FOR THIS SITE)
SOURCE: I need a code for hooking up a polaroid dvd player
You need the right tv remote code. Try to ger the code here
polaroid tv codes
SOURCE: DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
