I would only assume your connections to the wiring in the car are faulty, did you use solder joints and shrink wrap every connections you made? That is very important.
check you signal cables also check the signal from the source unit as well, this is normally why a error message will come up, try using the usb port to check for sound first or use your phone but change phone settings to MTP Media Transfer Protocol when connected via USB / Aux
Check and replace its tuner. It is at its main digital board. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
When your Brother PC 7500 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the Brother PC 7500 LCD screen, or buy a new machine.Brother no longer stock this item direct, but there is an affordable replacement available. Check this Link
Hello my name is Israel. I was able to locate a manual for you. You can go to the following website http://www.escortradar.com/pdf/7500manl.pdf. Hopefully this will help you. Thank you. Please rate.
Hey honestly what you need to do is send the unit back to pyle and they will repair it. I have the same issue 2 times. What they say is the players power supply went out and that 80% of issues with the pyle products are improper installation. I am selling mine and you should do the same after you get the player back. I hope I could help
