Question about RCA HD61LPW165 61" Projection HDTV
Audio fuzzy or cuts out
Sometimes the audio has a loud buzz noise when watching a show or when first turned on (when turning on with this problem - it emits a high pitch tone). Turning the set off, wait 3 minutes and turn on again and the problem is still there. Wait an hour and maybe the set works fine. Also, selecting the mute has no effect, the buzz is still there. The only way to stop the buzz is to select "Front Speaker external input". Using the sound signal out to an amp and back to the speaker works fine.
  • John in Mich Mar 01, 2008
    The problem is not the cables.
    When I do have the noise, I have no control over the noise, meaning I can not turn it down or adjust the volume of the noise.
    It is there with RF or audio input and makes no difference as to what source of video/audio.
    I have not taken the system apart yet but believe it to be the module, not just the transistor.
    The comes up as electronic dog training equipment. Is this the correct site?
  • 133 Answers
Could have a loose connection in the audio section or a problem with the output IC . Also does this happen on the RF input and your A/V inputs or just one of these. If its the A/V inputs only your having this problem check your cables .
Posted on Feb 27, 2008
  • Louis faenzi Mar 01, 2008
    The board you are talking about is the AV/IO module . Part # is 265751 it is available at or you can have it rebuilt at . Check to see who'll give the best price . Also before you purchase a board pull out your old one and check for loose connections . This could be your only problem. Since you said you can go to external output thru a amplifer and works ok . This tells me your preamp in the audio section is ok . Check around the input jacks and the audio output IC . This not a transistor and is mounted on a Heat sink roughly 1 x 3 inches . Good luck
  • Louis faenzi Mar 03, 2008
    Sorry i left out a few letters this should get you there .
Why does my system cut off when there is a loud noise?
By loud noise I assume you mean in the movie you're watching or the CD you're listening to.
That's the protection circuit kicking in. Depending on how you have the player configured (audio levels, effects, mode....etc) it can "overdrive" the outputs and cause the protection circuit to energize.
If this happens a lot try changing the audio mode to something a little less (change speaker levels to a lower number, no bass boost or at least not as much, etc.).
Good luck.
Jan 31, 2015 | Samsung Ht-P38 Sorround System Surround...
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 18, 2012 | Apple iMac Z0GF0005F Desktop
Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Apr 10, 2009 | Onkyo TX-SR606 Receiver
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Mar 25, 2009 | Sony KV-27V22 TV
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Hitachi VCR F361
You need to change the Audio / Control Head, as well as the Pinch Roller of the machine. A worn out Audio cum Control Head will reflect in poor tracking and so will cause the above problems.
Sep 29, 2007 | Hitachi VTFX631A VCR
Loud buzzing
check your connections again, if you have the audio and video reversed you will get this exact problem no video/ fuzzy video, and squealy noise out of only one speaker (other will likely sound correct) You're watching the sound channel, and listening to the video channel basically... hehe
Aug 14, 2007 | Zenith P42W46X 42 in. Plasma EDTV
RCA HD61LPW165 61" Projection HDTV Logo
101 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
