Its not that simple. As far as I know the windows software is linked to the computer the disk comes from so it won't boot up if put in a different PC. There are other ways of doing this but not for the non-techie. Do you want windows 10 or would you be happy with windows 7 on the 2GTb disk ?
Testimonial: "Thanks for your help Tony. I'd like to keep the Windows 10 as this drive has my stuff on it, But I guess I will have to format this drive? Would I be able to use this an external drive?"
SOURCE: 1tb hard drive with 2 500gb hd's which i need to separate
Use a third party tool to split the drive. Drive image has that capability.
SOURCE: External hard drive not recognized
You need to first narrow down the problem to either your PC or the external hard drive. Do you have access to any other PCs you could try connecting your hard drive to? (think friends, family, public PCs, etc)
If the hard drive works on other PCs, we know it isn't a problem with the hard drive.
If it turns out that the hard drive is fine and the PC is the problem, I would suggest going in to Device Manager and uninstalling everything USB related. Once you have done this, either reboot your PC or right-click inside device manager and "scan for new hardware". All of your USB related devices should reload their drivers automatically. You may want to try this both with and without the usb drive connected.
Another tip would be to try various USB ports.
SOURCE: Western Digital Reset / Set Hard Disk Size ?
hit F1 when you bootup dont let windows come on . Go in you Biso to set you new hard drive.dont forget to F10 to save changes...Good Luck
SOURCE: computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
SOURCE: I have a seagate 500gb freeagent external hard
Windows 7 probably don't recognize it. keep an eye out for it at the manufactor website, for a driver. Windows 7 is turning out to be like windows vista
Hi Muriel, it should be possible to connect the 2TB drive externally to the windows 7 laptop so that you can read your personal files on the 2TB drive. What you need is a USB to SATA hard drive docking station or a suitable disk caddy. If you give me the part number of the 2TB drive I should be able to recommend something. You don't need to reformat the drive.
Thank you soo much for doing this Tony. OK. PN: 9YN164-501 Model: ST2000DM001
Something like this:https://www.amazon.co.uk/s/s/ref=sr_nr_p...
Recommend you get one that supports USB3 or 3.1 and must fit a SATA III 3.5" disk drive.
Once you have fitted the drive in the product just plug the USB cable into your old laptop and you should be able to read the files off the 2Tb drive. Good luck
SATA III is also sometimes called SATA 6Gb. USB3.x is also backwards compatible to USB2 but it is faster and will future proof you if you get a newer laptop.
Thanks once again Tony. I am not a total novice and I was keeping up with technology to some degree, or so I thought, until Microsoft decided they wanted to run my computer how they saw fit. I am in my 60's now so I guess I will be needing a bit more help and guidance with these things soon. LOL. Thanks again Tony your help is much appreciated. Have a great day.
Cheers
Muriel
