Question about Intel D845GVSR Motherboard
Replace my motherboard warrenty and change the Graphics (IC) not print intel
  • 657 Answers
Re: Replace my motherboard warrenty and change the Graphics (IC) not print intel - Intel D845GVSR Motherboard Motherboards
Huh? not sure what you are asking for here.
Posted on Dec 05, 2007
0 characters
3 Points
Is i3 processor is compitable with msi 945gcm5 ver:4.2 motherboard
The Intel 945GC motherboard chipset, will not support the new Intel Core i technology.
MSI 945GCM5 Version 4.2,
(It's also the MicroStar International MS-7267)
Specification / Detail / Detail Specification;
Intel 945GC chipset
CPU (Processor) Support,
With your motherboard, the motherboard chipset consists of a Northbridge chip, and a Southbridge chip; for the motherboard chipset,
The Northbridge, and Southbridge chip are so aptly named; because of the relation to how they sit on the motherboard.
If you looked at the motherboard as a Map; the Processor (CPU), sits due North. The Northbridge chip is located close to it.
The Southbridge chip sits South, or towards the bottom of the motherboard.
The Northbridge chip handles the faster capabilities of a computer.
Handles the Processor (CPU), Ram Memory, and HIGH-speed graphics.
AGP and PCI Express are HIGH-speed graphics technology.
A PCI graphics card inserted into a PCI slot, or using Integrated Graphics; is NOT high-speed graphics.
The Southbridge chip handles the Slower capabilities of a computer.
1) Anything inserted into a PCI slot, or connected to the PCI bus.
2) IDE bus
3) SATA bus
4) USB bus
5) Ethernet bus
6) Audio (Sound)
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
[Just for edification while I'm here;
The I.C., or chipset used for graphics; is the graphics chipset, or more properly known as the G.P.U.
Graphics Processing Unit, ]
The Intel Core i technology, did away with the Northbridge chip.
It also uses QPI, or Quick Path Interconnect; instead of a Front Side Bus, (FSB),
Plus you have an LGA 775 processor socket, and the Intel Core i processors use either an LGA 1156, or LGA 1366, or LGA 1567, processor socket,
Dec 20, 2012 | Sony Motherboards
Maximum graphic card memory
You could increase to a 1000Gig's if they made one.
A graphics card has it's own graphics processor, and graphics ram memory. It runs independent of the System Resources.
The Processor and Ram Memory.
Integrated Circuit,
The graphics I.C., or graphics chipset, is a GPU,
A GPU can be mounted directly to the motherboard, and use some of the system resources. Integrated graphics.
Or it can be mounted to a removable graphics adapter card.
IF there IS a 'bottleneck', it will be your Processor, and amount of Ram Memory.
Should have at least 2GB of ram memory
It will take up to 4GB. can also support DDR2 Sdram at 667MegaHertz. (PC2-5300)
Intel 945G motherboard chipset.
Intel 82945G Northbridge chip,
Intel 82801GR Southbridge chip. (ICH7R)
Supports Intel Core2 Duo processors, with a Front Side Bus of
UP TO 1066MegaHertz. (FSB up to 1066MHz)
Intel 945G chipset was brought out in 2005. This means to me, the PCI Express technology used on your motherboard, is
PCI Express 1.1
I would stick with the graphics cards using PCI Express 2.0 technology.
I've read reports where the PCI Express 2.1 cards, weren't 'playing nice' with motherboards using the PCI Express 1.1 technology.
Unless you just wanta' experiment? Who knows?
How many maximum Watts is the Power Supply, capable of delivering at 80 percent, and how many Amp's does the 12 Volt power rail have?
(If there is more than one 12 Volt power rail, you can add together for the total 12 volt Amp's )
See what the minimum requirement is for the Power Supply. make sure you have MORE than enough.
Also if the graphics card requires an additional power cable; make sure your Power Supply has it.
But the minimum wattage for the Power Supply is 450 watt.
Power Supply? 500 Watt.
Jul 18, 2012 | Intel D945GNT Motherboard
Intel 845GVSR Motherboard no display Problem
no diplay in this board give me sme notes to chag ic.what ic i did change
Jan 23, 2009 | Intel Motherboard
How to replace a intel motherboard :
Please go to the vendor or shop from where you've purchased the board. They'll contact Intel for you and get the board replaced. Do it asap because depending on the location, it takes a month to reach Intel.
Sep 04, 2008 | Intel Motherboard
Motherboard Intel D101GGC no display
Hello dheyx, your Intel D101GGC board used an intergated ATI Radeon Xpress 200 graphics. If you lost display than you're intergated Radeon has died. Suggest you replace it with a
PCI-E X16 graphics card. The Intel D101GGC board does have an opened X16 PCI-E slot. Do not forget to change the bios video card setting. You want the board to see& load the PCI-E first.
Apr 24, 2008 | Intel D101GGC Motherboard
Audio Device not working
if your motherboard warrenty is ........................if you go your vender to change it .other way to setup properly.......
Apr 10, 2008 | Intel D102GGC2 Motherboard
Mother board dead
Hello how are you. Please give me ome detailed information the make and model of the computer. i will help you with this. Easy. This is what I do for a living.
Thank you hope to here from you
Feb 10, 2008 | Intel Motherboard
Problem in one IC
i want graphics driver
Feb 08, 2008 | Intel D845GVSR Motherboard
Not sure what information you were requesting. So here is some information about your motherboard:
- LGA775 socket for Intel® Core2 Duo/65nm Pentium D/Pentium 4/Celeron CPU
- Intel 865G + Intel ICH5
- 1066(O.C)/800/533 MHz
- Dual-channel DDR400
- Intel® Extreme Graphics 2
- 1 x AGP 8X
- 2 *ATA133 ,2 x SATA
- 10/100/1000 LAN
- 6-Channel audio
Here is a link to all the drivers to your motherboard:
This includes the manual!
If you need more help Let me know. :]
Dec 10, 2007 | ASUS P5PE-VM Motherboard
Intel D845GVSR Motherboard Logo
16 people viewed this question
Top Intel Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Intel Motherboard Expert? Answer questions, earn points and help others
