Question about GE Kitchen Ranges
Bottom drawer stuck on ge true temp gas range
    Habit-Forming:
  • 107 Answers
Ah yes, the ultimate battle. Unfotunately if you want to get the bottom drawer unstuck yourself you're going to have to fight with it. The best way to get this drawer out other than asking your kids to try, is quick jerking motions back and forth holding both sides. Make sure you keep the stove secure while you battle this. If you can get it open some of the way, use a stick or something to try to jumble up all the pots and pans you have down there keeping it from opening. If you have nothing in the drawer, then maybe use a broom handle to pry it out, or have someone tilt the stove back to see what's restricting it. If worst comes to down to it, you can call a repair guy and watch him struggle to get it open.
Posted on Jan 25, 2019
SOURCE:
  • 213 Answers
SOURCE: Need to clean oven GE true temp self clean
the oven temp sensor is bad. replace temp sensor to solve problem
Posted on Nov 19, 2007
jumptrout51
  • 3361 Answers
SOURCE: Don't know how to start the self cleaning oven. Please advise.
Most service techs will advise you not to use self clean features on a oven due to excessive parts failures from the extreme heat.
Posted on Feb 21, 2009
MNTECH
  • 1543 Answers
SOURCE: GE True Temp oven won't turn off.
The sensor is a part number WB23T10002 and goes for about $60. The paper inside the control area of the oven will state the normal resistance values of it. (probably about 1080 ohms at room temp, about 2650 at clean temp.) If you cut a lead to it, you would just get a F3 code, and if you cut the other and wire them together, just get a F4 code, so that wouldn't help diagnose the problem, but if you could use an ohm meter on the probe it would. BUT the oven should not come on without it being set to bake, SO I conclude that the ERC is indeed the problem (with the welded electrical contacts), which is a part number WB50T10043 which might go for about $125 or so. If you are careful when you replace it, you can probably peal the faceplate (part # WB27T10125) off and reuse it, so you should just need the ERC.
Posted on May 07, 2009
  • 69 Answers
SOURCE: is the broiler on whirlpool gas range located on
yes
Posted on Jul 30, 2009
  • 715 Answers
SOURCE: I have a GE XL True Temp gas range/oven. None of
your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
Posted on Oct 07, 2009
My stove drawer is stuck and it won't close or come out , what to do ?
drawer is stuck Anon, Pick up on drawer as far back as possible with some force,shake it up and down, this should allow you to lift drawer from track/slides. Clean and lubricate all wheels, bearings and track/slides and reinstall drawer.
HELP bottom oven drawer stuck on new GE range
How to Open an Oven Drawer That Is Stuck eHow
How to Unstick Oven Drawer
Stove Drawer Stuck or Jams DIY fix
Apr 02, 2016 | Kitchen Ranges
Stuck slide drawer on ge spectra
Check to see if the glide rail has been bent of if something is actually pinned under the stove it self sometime tile or and rug will get caugh in the drawer. after that's all clear the only other issue I can see is if cleaners of some sort have drained down unto the drawer slide, or the drawer slide is bent or off track some how.
Jun 09, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
The bottom drawer is stuck closed is there a way to take off the door and see what is stuck inside?
You probably can't remove the drawer front without it being open so pull the range away from the wall, remove the bottom/back cover and fix the problem from back there.
Dec 05, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
Ge gas oven not working
thermocoupler needs to be replaced...
Dec 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oct 07, 2009 | GE JGBP28 Gas Kitchen Range
We're spraying for buts, and I have a GE True Temp. how do i turn off pilot lights? thanks!
you turn off the gas to your house. it has an electronic ignition and will restart once you turn on the gas and use the oven
Jul 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Jammed storage drawer
svineyardWelcome to fixya.
I'm Huuum and happy to assist you,
You said, Y inherited a GE Spectra XL44 in the home I recently bought so you don't know much about it. There is a pan stuck in the storage drawer and You can only open the drawer about an inch and a half before it jams.
You need two people.
One strong person to slide the range forward, so he can tilt the range far enough back, that you can access the drawer from the bottom and the pan will fall back inside the drawer as you pull the drawer forward and out enough for you to reach the pan and turn it around or what ever you need to do to get it out!
Bravo, I want to hear that you succeed!
Be careful not to hurt your self.
Bless You Huuum.
Please do not forget to leave a rating when you are done.!!!!!!!!
Aug 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Stuck warming drawer
sadly there is no way from the top . only thru the door .
Nov 11, 2017 | GE Profile Spectra JGBP85 Gas Kitchen...
Warming Drawer stuck
Pull the oven out and see if you can get to the pans from behind.  May have to lift up on the back of the oven to get out fallen pans.
Oct 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
74 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
