my nephew gave me his netgear randemax wireless router model WPN824NA, with the setup cd. i follow all directions correctly when the setup cd gets to the point of powering up the router it says lights should come on except for the wireless light. well the wireless light blinks on and off and then the setup cd says it can not find internet. they do not say what it means when the wireless light flashes on/off. i've tried resetting the router. i have comcast cable internet and also a voip router for packet 8. i've tried eliminating the voip router but still get the same result.
any help would be great, net gear won't talk to me because its past warranty.
thanks john
Light blinking on Netgear router means that the wireless is "working". Mine did the same thing. I had reset my network to 192.168.2.x instead of the default 192.168.1.x. Since this is usually on a diferent subnet it logically is on a different network and will not connect. From your post it sounds like you know what you are doing. If the config software for the router loaded correctly then there should be an icon in your Network path that shows the router. Double clicking should let you in by default. Set the IP address to your local network and try again.
Was this helpful?
Yes
No
Popular Solutions for D-Link DI 514 Wireless Router
everything was perfect during the installation till when i was going to start lan...how can i...
(More)
EVERYTHING WAS PERFECT DURING THE INSTALLATION TILL WHEN I WAS GOING TO START LAN...HOW CAN I CONTINUE WITH THE WIZARD PAGE TO CONTINUE MY INSTALL? MY ROUTER D-LINK DI 524
Dl-514 is not connecting to DSL PPPOE. I have keep disconnecting the power cable to reconnect, Seem...
(More)
Dl-514 is not connecting to DSL PPPOE. I have keep disconnecting the power cable to reconnect, Seem it is not trying to dial.
