SOURCE: Phone Lock - Samsung SGH-X670
The Phone-Lock is a manually set code, this means that you or the previous owner set this code on the phone to prevent it from being stolen. Consult the previous owner to get this code. Second option is to have Samsung remove this code for you, but this option usually costs money. SIM-lock can be removed by contacting the provider the phone is locked to.
SOURCE: Samsung PS42C91H plasma tv
I think you have a fault on the line output stage either dry solder joints or a fault with components on the line output stage or a faulty line output transformer. If you can check this for yourself otherwise find a competant technician. Hope this helps.
SOURCE: network locked: and now phone freezed: samsung sgh-m150
please send circuit diagram of network of sgh-m150
SOURCE: How can I activate blackberry messenger on blackberry 9930 in south africa
You first need to buy R60 airtime for the network you are using such as MTN, Vodacom, Cell C etc. That R60 will be the amount you need for (BIS) Blackberry Internet Service. You need BIS to enable BBM (Blackberry Messenger) to work. Once you have topped up your airtime with R60, you need to dial *141*11# which should bring up the option to activate BIS. Choose BIS and not any other option. BIS is usually option 1, but just make sure you select to activate BIS. Once BIS is activated then you can go onto BBM (Blackberry Messenger) and you should be able to send messages. You then have internet access as well. The great thing about the BIS is that it lasts for a month, without you needing to pay anything after the R60 to send as many messages as you like for free on BBM, plus you can use the internet on your phone as much as you like too! I am experiencing a problem getting BIS on my Blackberry Curve which I shall ask a question about on this site!! Good luck :)
