Question about Fargo DTC550 Thermal Card Printer
Fargo DTC550 The printer ribbon keeps breaking. Is there a tension setting?
  • Anonymous Feb 11, 2008
    Ribbon keeps breaking, specifically on the yellow streak.
  • Tinker2008 Nov 17, 2008
My printer is Fargo DTC550 and I'm using HID 1326 card for printing. I cannot get this equipment to function correctly. I had no
problems installing the software and hooking up the printer to make the ID
cards, but all attempts to print an ID card have failed. Every card I have
tried to make has been unsatisfactory, with colours not printing, very poor
image quality, and the lamination device consistently jamming for every
single card I have tried to make.
Sir, please help me.
Posted on Oct 04, 2008
Reduce the Magenta settings
Posted on Mar 17, 2008
I have the same problem...
Posted on Sep 08, 2008
Pictures and information on ID cards rubs off after printing
Go into "Printers and Faxes", found in your start menu. Right click on the printer (Dtc 550). Select Printing Preferences. Under the "Device Options" tab, click "Auto Ribbon Select" (make sure to have the ribbon installed, as you would normally).
After being prompted with a "Success" message, try printing again.
If the problem persists, you need to update the printer's firmware. you can find the firmware file and update utility, Fargo Workbench, here Drivers Downloads
Apr 07, 2014 | Fargo DTC550 Thermal Card Printer
I have a Fargo DTC550 Printer and laminator which i just got yesterday and after setting it up by carefully following every instruction in the manual it keeps displaying "Wrong Ribbon Installed" "An...
in windows 7 go to start>Devices and Printers> Right click on DTC550 and go to printing preferences then click the Device Options tab and click auto ribbon select
Oct 20, 2010 | Office Equipment & Supplies
DTC550 Fargo printer it says out of ribbon with new installed
Check to see if the RFID (green ring) from the old ribbon has come off and is stuck near the reader (located behind the green stem). I've seen that happen. I've also see some bad RFID rings. If that happens they should have a warranty from Fargo.
Mar 19, 2010 | Fargo DTC550 Thermal Card Printer
My printer displays ribbon error. but there is ribbon inside
you can change which ribbon type is installed in the printing preferences of the printer driver.
make sure you have the right ribbon type selected.
CYMTKO vs. CYMTO, etc.
There is also a button that will auto detect the ribbon right underneath the pulldown menu.
May 26, 2009 | Fargo DTC550 Thermal Card Printer
Printer keeps breaking the ribbon
first, try to calibrate the ribbon, if it does not work, you probably have worn out rollers, and possibly a broken o-ring. if you want more info, call us at 310-671-8018, thanks adi
Mar 25, 2009 | Fargo DTC400 ID Card Printer Package
Ribbon align error
Try Calibrating the the print ribbon through the print driver printing preferences on the calibrate tab.
Sep 25, 2008 | Fargo DTC550 Thermal Card Printer
Bad print heads
This is a continuing problem we have with our Fargo DTC550 printer. If you remove the printhead from the printer and look at the underside you will see a nick on the head in the same area you are getting a line on your card. Fargo claims we damaged the head due to not keeping the printer clean even though we clean at every ribbon change. I believe that the damage happens when a plastic debris (from the plastic card) gets between the card and the head. You must check your card stock to make sure there is no plastic debris on them. Bottom line, you have to replace the head and at the time it costs $700 per head.
Apr 30, 2008 | Fargo DTC550 Thermal Card Printer
The is usually resolved by replacing the head lift motor or sensor.
Dec 17, 2007 | Fargo DTC550 Thermal Card Printer
Fargo DTC550 Thermal Card Printer Logo
957 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
