SOURCE: iT FELL ONTO A CHAIR THE SCREEN WENT BLACK YOU
You have either permanently damaged the LCD display or the inverter board ( which is repairable )
The display will be almost the cost of a new set.
SOURCE: It fell off the coffee table and now the Zoom lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
SOURCE: I bought an emerson tv
can you return the tv? I got mine from my dad for christmas and its already screwed up. Just sitting there on my bed suddenly the tv starts flashing different colors and pops. Right after it startled me I turned it right off. Then I turn it back on and change the channel, 5 minutes later the same thing happened, so I unplugged it and thats how it is right now. My point AKA the tv is ****.
SOURCE: HOW DO I HOOK UP AS A COMPUTER MONITOR EMERSON LC320EM1F
The Emerson LC320EM1F has an HDMI connector (HDMI 1) that can be connected to a computer with an HDMI out or a DVI out. With a DVI connection, you will need a ferrite core on the HDMI cable. You can use a DVI to HDMI cable or a DVI to HDMI adapter with the appropriate cable. You will also need a 3.5 mm to RCA (M/M) audio cable (or the adapters and cables) if you want to use the TV speakers. If you have only a VGA output on the computer, you will need an analog to digital converter (like this: http://www.startech.com/AV/Converters/Video/VGA-HD-with-Audio-to-HDMI-Format-Converter~VGAHD2HDMI ).
You can find the manual for this TV including the connections here: http://www.emersonaudiovideo.com/support/download.php . Enter your model number and then the list of manuals will appear. The connection to computer diagrams is on page 13.
Once you have your cables (you will get the best prices from an online shop), turn off both the computer and the TV. Connect the cables then turn on the TV and set it the HDMI 1 input. (Use the Source button on the remote. You can also press CH Up repeatedly.) Then turn on the computer. If your computer has a recent version of Windows, it should see the TV automatically if the port is active on the computer. For a laptop, you will need to change the display settings to use the TV monitor. Right click on the desktop (anywhere there are no icons or programs), find the Display properties option. Set the monitor option to use the second screen (extended or monitor only). Click Apply and confirm the setting on the pop-up. (These are Win7 directions; other OS versions will be similar.) For a desktop, you may need to go to the Screen Resolution option after right-clicking. (This is a shortcut to the Control Panel Display settings window. Thus you can also click Start > Control Panel > Display to get to the right area.)
Some machines may need the port enabled in the BIOS first. This applies more often to older laptops or those with a power-saving option that turned off unused ports. You will need to enable the port with a different monitor active before connecting to the TV. Accessing the BIOS varies but usually involves pressing Esc, F1, F2 or F10 repeatedly after you turn on the computer. I often miss the timing; just turn off the computer and try again if the OS loads or the log-in screen appears.
If you get an unknown mode message on the TV, the previous monitor may have used a refresh rate and resolution that the TV can't understand or the TV was turned on after the computer was turned on. If it's the second case, press CTRL-ALT-DEL twice or turn off the computer (you will see a warning that Windows was improperly shut down). Then turn on the computer. If you have the first issue, go to the previous monitor and use the Screen Resolution directions above. Set the refresh rate to 60 Hz. Set the resolution to 640 x 480, 800 x 600, 1024 x 768, 1280 x 768 or 1380 x 768. (The options will be limited to those that are compatible with this monitor.)
I hope this helps.
(Note only HDMI 1 supports a computer signal; the other ports will not understand the computer's video output.)
SOURCE: My Emerson LC320EM1F model tv went out and didnt have power about a year ago so i let it sit until
sounds like you've spent lots of money trying to fix it already. Hope someone here can help.
