SOURCE: How many gallons per hour does this car lose?
hey
at the begging u should clarify how many gallon u used.
112 miles at 28 miles per gallon --> 4 gallons burned (112/28)
So that means we leaked 11 - 4 = 7 gallons
Now figure out how long the car was driving.
112 miles at 64 miles per hour --> 1.75 hours
So, leak was at a rate of 7 gallons in 1.75 hours
7/1.75 = 4 gallons per hour leaked.
SOURCE: 1995 Saab 900 Won't Take A Fill Up
Sorry if this gets posted twice. I have a 95 Saab 900, which I just acquired. I can get only about 4 or 5 gallons in at a time. The best analysis I found was this one where the man pinpoints a stuck valve in the gas tank, and tells of what he did to address it.: http://www.quasimotors.com/9_5_gas_fill_prob.htm
SOURCE: 2000 Ford Expedition Starting problem
If the fuel gauge drops off when you are driving then its a sending unit problem that means you have to drop the tank and replace the float and sending unit. This is a common problem for alot of cars because of cheap gas. If you have to drop the tank check the fuel pump canster for dirt because of cheap gas. Replace the fuel pump strainer and fuel pump filter. If the car or truck has about 100,000 miles you might want to change the fuel pump at that time also just to cover your back. If you take it to a shop they will charge you at least $900 to start. But if you do it yourself it will cost you about $200 dollars maybe alittle more.
SOURCE: how many gallons does my gas tank hold?
1997 OLDSMOBILE BRAVADA
SPECIFICATIONS
Manufacturer's Suggested Retail Price $ 30,285
Price As Tested $ 30,800
Engine Type 4.3 Liter V6 w/SCFI*
Engine Size 262 cid/4300 cc
Horsepower 190 @ 4400 RPM
Torque (lb-ft) 250 @ 2800 RPM
Wheelbase/Width/Length 107"/66.5"/180.9"
Transmission Four-speed automatic
Curb Weight 4043 pounds
Fuel Capacity 18 gallons
Tires (F/R) P235/70R15
Brakes (F/R) Disc (ABS)/disc (ABS)
Drive Train Front-engine/all-wheel-drive
Vehicle Type Five-passenger/four-door
Domestic Content 95 percent
Coefficient of Drag (Cd.) N/A
More details: www.theautochannel.com
Hope help you; good luck (remember rated ths help).
SOURCE: high fuel consumption. only 200 miles per tank
it has gotta be the o2 sensor, map sensor, or the mass air flow meter.............. these are the main inputs to the computer that controls the fuel control....let me know how that works out please
