Question about Advance Computers & Internet
How can we cut the strong Neodymium Magnetic Plate which is 20mm thick and length 150mm width 100mm . I have triad to cut it through CNC Cutting machine also other cutting tools
Look for Neodymium Magnets a href=https://bloomenterprises.co/product-category/magnets/Buy Magnets online/a cutting of neodymium magnets looks very hard guide me . Thanks in Advance
    Top Expert:
  • Advance Master
  • 25,062 Answers
I would think if you tried carbide tooling that diamond would be the last hope
Posted on Jan 06, 2019
Testimonial: "Thanks very much Steve i ll try to cut it through <a href=https://www.bloomenterprises.co/product/carbide-rotary-burr-cutters/">Carbide Tools</a>or Diamond Tips if it could solve"
SOURCE:
escapement
  • 2338 Answers
SOURCE: i want to see how Software programming for cutting
Try YouTube. I've seen some CNC machining there. Also visit Swiss manufacturer original sites.
Posted on Jan 13, 2010
danny_murray
  • 55 Answers
SOURCE: ryobi cutting tool
You should be able to pick up just about anything you can imagine for a ryobi at lowes or home depot
Posted on Dec 05, 2008
ftw1952
  • 10319 Answers
SOURCE: I have just purchased a
You must use a level to determine the wheels are perpindicular straight up and down evenly. The wheels do have adjustment to loosen to angle the position correctly as all band saws do
Posted on Oct 19, 2010
wentlanv
  • 710 Answers
SOURCE: one question, im looking to
The K760 black cutter blade is called a Cut-n-Break blade. The manufacturer states that it has an improved stable core to increase its performance. I have a friend who recycles scrap metal and uses the Mastercraft 5" dual cutter. It cuts through metal like butter without any kickback.
Hope this helps,
Handie Andie
Posted on Mar 26, 2011
  • 53745 Answers
SOURCE: Can a USB pen-drive / flash be erased by strong magnetic field?
if you simply want to reuse flash drives or usb gig sticks why not simply reformat them
plug them into the computer , right click on them click on the properties tab and click on the format heading
remember that ij every flash drive or usb stick there is a small amount of memory ( like a bios) that controls the working of the unit so to hit it with a massive magnetic field will wipe out that bios as well rendering the unit as junk
when you get a usb stick or flash drive or the like , you will buy it as say a 4 gig unit but when you plug it in you will see that there is not 4 gig available for use but 3.9 gig
the .1 gig is the bit that I refer to as the bios of the unit
Posted on Oct 16, 2017
Testimonial: "Thank you. Very Helpful!"
I have a 2003 z71 subaran and the rear end went out.would a 2005 tahoe rear end work in a 2003
You need to check 2 measurements. The overall width of both rear ends, backing plate to backing plate. You also need the width between the spring mounting plates on both rear ends. If these measurements are the same you shouldn't have any problems. If they are not the same, keep looking. If the overall length is shorter, your tires will rub on the body. If it's longer, your tires will stick out and rub on the fender.
The mounting plates can be moved, if the measurement is different, but that involves cutting and welding and it would likely be cheaper to get a different rear end. Braking systems should be an easy swap if it is necessary but they should be the same. Hope this helps.
Mar 22, 2011 | 1996 Chevrolet Tahoe
Cannot use die cuts
No I don't think your machine is defective. Here are some "sandwich" ideas to help you. I know you asked just for Cuttlebug dies; I included other "sandwiches" that you can do with your Cuttlebug. If you need further assistance feel free to contact me.
Cardstock
Chipboard
Magnetic/ Metal Sheets & Thin cork (Media)
Cuttlebug Dies
Plate “A”, Plate “B”, Die (cutting side up), Cardstock, Plate “B”
Plate “A”, Plate “B”, Die (cutting side up), Chipboard, Plate “B”
Plate “A”, Plate “B”, die (cutting side up), Media, Plate “B”
Cuttlebug Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”
Plate “A”, Plate “B”, Folder (with chipboard inside), Plate “B”
Plate “A”, Plate “B”, Folder (with metal sheet inside), Plate “B”
Nestabilities
You will need Spellbinders Tan Embossing Mat to emboss in
Cuttlebug™ machine (or a plumbers gasket cut to size, or some use a mouse pad)
Cutting Sandwich - (Stack from bottom up)
1. A plate
2. C plate
3. Spellbinders Die (cutting side up) that means the side with the
ridges
4. paper or cardstock
5. B plate
6. Run through Cuttlebug™ machine.
Embossing Sandwich- (Stack from bottom up)
*Remove C Plate for embossing sandwich
1. Place A plate on bottom
2. Leave die face up on A plate with die cut still in the die.
3. Place one Spellbinders Tan Embossing Mat on top of the die.
4. Use 2 or 3 pieces of cardstock to shim.
*Cautionary Note: Using more than 3 pieces of cardstock to
shim Cuttlebug Embossing sandwich will result in B Plate
breakage. When using Spellbinders Edgeabilities card making
dies, shim with only 2 pieces of card stock.
5. Place two acrylic B plates on top of sandwich and run thru
Cuttlebug machine to emboss Spellbinders die cuts.
6. Turn die over and use like a stencil with inks and chalks for
added detail.
BigShot Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”, Cardstock shim
BigShot Large Dies
Plate “B”, Cardstock, Die (cutting side down), Plate “B”
Revolution Dies
Plate “A”, Plate “C”, Die, Cardstock, Plate “B”
Sizzlit Dies
Note: Provocraft suggests using Plate” C” instead of the second Plate “B”, however, CB owners have cracked plates, so try with two “B” plates first.
Sizzix Original Dies & other Steel Rule Dies
Plate “B”, Chipboard, Die (cutting side down), Plate “B”
Sizzix CutNFold Dies
Plate “A”, Die, Cardstock, Plate “B”, Chipboard shim
Also try:
Plate “B”, Cardstock, Die, Chipboard shim (maybe 6 layers)
Sizzix Embossing Folders aka Simple Impressions
Also try:
Plate “A”, Chipboard shims, Folder (with cardstock inside), Plate “B”
QuicKuts Dies (Regular)
Plate “A”, Plate “B”, Die, Cardstock, Plate “C”
Plate “A”, Plate “C”, Die (cutting side up), Chipboard, Cardstock shim, Plate “B”
QuicKuts Dies (Grand)
Brass Embossing Stencils
Plate “A”, Plate “B”, , Brass stencil ,paper/cardstock,mouse pad (cut to size, rubber side down), Plate “B”
Sandwich may need to pass through several times based on cardstock thickness
Or use plumber’s black rubber plus red rubber gasket, instead of mouse, then add last plate B.
Big Impressions Texture Plates
Plate “A”, BI texture Plate, Cardstock, Silicone Rubber pad (from BISK), Impressions Pad (from BISK)
*BISK-Big Impressions Starter Kit
Fiskars Texture Plates
Plate “A”, Fiskars texture Plate, Cardstock, tan Wizard pad, black or tan Wizard pad, (possible Cardstock shim,) Plate “B”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (lightly misted with water), 2 layers Fun Foam, Chipboard Shim, Plate “C”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (right side towards TP), Rubber Plate (made from Plumber’s rubber gasket), Plate “C”
Plastic thin stencils
Here too- may try
Plate “A”, Plate “B”, , plastic stencil, cardstock, black rubber, red rubber, plate B
Jan 28, 2010 | Provo Craft Cricut Disney Font Cartridge
I want to see how Software programming for cutting of a new watch model on the CNC machine is used
Jan 12, 2010 | Casio Watches
My mower is not cutting level. I have a new base
If the baseplate meets the cutting cylinder across the entire cutting width, it's adjusted properly.
Check that the front roller is level - it usually IS as simple as that.
If the roller has ben replaced with wheels, check that they are the same height.
Aug 22, 2009 | Garden
Installing a deadbolt in a steel door. need to find the best/easiest way to get the plates recessed. using a cold chisel is a huge pain. hopefully thats not the only way. unless i'm doing it wrong.
A really, really, REALLY sharp chisel can be used to pierce the steel door skin enough to form the mortise you need for the bolt plate. Do not use a wood chisel unless you never ever intend to use it on wood again or have the means to completely renew the cutting edge. Cutting the opening for a plate in a metal door jamb is another issue since it is probably too thick to yield to a chisel. If the jamb is 1/8 to 1/4 inch thick you can just drill a hole in it to accept the extended bolt. it will be just as strong as a plate (maybe stronger.)
Jul 29, 2009 | Kwikset Brz Sgl Cyl Deadbolt
Canon printer MP110
ok clink the above link directly
Nov 16, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Cutting size question
* f your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
Cut off question
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Aug 27, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Computers & Internet Logo
Top Advance Computers & Internet Experts
Marvin
Marvin
Folusho Adeyanju
Folusho Adeyanju
 steve
steve
Are you an Advance Computer and Internet Expert? Answer questions, earn points and help others
