Question about Palm Tungsten E2 (Multilingual) Handheld
Tungsten E2 I have a Tungsten E2 that I have not used for a long time. I tried to charge it last night, but, even after being plugged into the charger all night long, the screen is still dark. I tried pushing the on/off button on the top right of the device, but it doesn't really even push. Is something supposed to light up to tell you that it is charging? I don't see a light anywhere either. Can you help?
    Problem Solver:
  • 5 Answers
Re: Tungsten E2
Have you tried pushing the reset button on back to see if it comes on?
Posted on Dec 21, 2007
0 characters
3 Points
My Tungsten E2 is not charging. It has been with me for almost 4 years now. What seems to be the problem? This is not the first time though I encountered the same problem. 3 years ago I encountered the...
I had symptoms with my Tungsten E2 where the charging icon would show up when the charger was connected, however, it didn't seem to charge, because when it was removed from the charger hours later, it would still show the same percentage of charge (as read by touching the battery icon while in the favorites screen).
Tried resetting the unit, reconnecting multiple times, different charge cables, and it was always the same.
I thought it might be time for a new battery, so to check it out, I got my T-5 Torx driver, removed the four case screws, and carefully pried open the case from the top (the bottom has hooks that have to be disengaged by sliding the case half downwards after they're separated from the top)
Measured the battery and it seemed to be okay, and after unplugging the battery connector and reconnecting it, it worked normally again. Charged quickly back up to 100%, and the battery is fine.
It looks like something may get out of sync with the battery charge circuit, and by simply unplugging the battery to allow it to reset, it restored operation, no replacement battery needed.
Sep 27, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Tungsten e2 won't power up
Please follow the steps to isolate the problem:
1. Make sure that the charger is working.
2. Try using different charger just to make sure.
3. Try using different battery.
If the phone works using different battery, you need to replace your old battery, but if not, this phone needs repair.
Apr 17, 2009 | Palm Tungsten E2 Handheld
Will not turn on
It's possible that the battery can no longer hold a charge anymore.
Check with Palm to see if there is a replacement available.
It should work if you have a car charger on it while using it.
Mar 31, 2009 | Palm Tungsten E2 Handheld
Tungsten E2 wont power on
Turn it on pressing the reset at the same time or take out battery and unplug/plug the battery. Your battery may have died. If this is helpful, post as such. If it is a fixya, post as such. I had an E2, can tell you alot about it. TY
Jan 23, 2009 | Palm Tungsten E2 Handheld
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Will not fully charge
its possible its losing the connection overnight, which could mean its something with the charger port in your phone. Have you tried other batteries or chargers with the device
Nov 18, 2008 | Palm Tungsten E2 Handheld
Tungsten E2 will not power on
The Tungsten is an excellent PDA
You do have to be careful with how you handle it if you've dropped it too many times or set it down too hard or whatever something inside will get cracked or disconnected.
So you may want to open it up (personally I use a really small screwdriver but there is a kit for 9.95 on that comes with a Shim like tool that is really useful for splitting the Tungsten open because its not easy getting it open and closed)any way open the back up and make sure everything is connected and clean especially the connectors to the screen, battery and USB/charging plugs. You may also need to try charging it overnight. If you haven't run the PDA in a while its going to read a full charge regardless of how much of a charge its actually holding. Also, there are alot of other places to get A PDA repaired do a little research and find a place near you that will repair a PDA. An official Palm repair is almost always going to cost you more than anywhere else.
Jun 06, 2008 | Palm Tungsten E2 Handheld
Won't turn on I press the power button
Press the reset button on the back of the unit with the stylus tip.
Apr 23, 2008 | Palm Tungsten E2 Handheld
Tungsten E
Hi : This means your battery must be as dead can be. Therefore it seems to be getting straight power only when you plug in the charger. Or your on/off button is dead. Are you able to turn it off/on when you have charge plugged. If so then I suggest getting a new battery for the E2 Palm and you should be back up and running. If this is not the case then it is your on/off button in which it could be just the contact or the switch itself. I can suggest someone in US if you like, else I can handle it but I am in AUS.
Oct 02, 2007 | Palm Tungsten E Handheld
Palm Tungsten E2 (Multilingual) Handheld Logo
67 people viewed this question
Top Palm PDAs Experts
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
