Question about Radio Communications
Mobile radios cant be heard by the base radio unless the base radio calls first and then the mobile can be heard as long as it replies within a few seconds.
    Habit-Forming:
    Scholar:
  • 69 Answers
Can your mobile radios talk to each other? If so, your base has the problem. You may have the wrong selective calling features loaded, or if you aren't using selective calling like CTCSS or DCS, then try using monitor mode on the base. That will let anything through. You may also find that your squelch control is set to high. Try turning counter clockwise until you hear noise, then turn it clockwise until the nloised stops.
Posted on Jan 12, 2019
  • 490 Answers
SOURCE: nokia 6070 mobile handfree unit not work with mobile
sir.may b fault is lying with the radip option in ur fone...chk ur visual radio settings frm service provider....
Posted on Oct 22, 2007
  • 13433 Answers
SOURCE: Radio Shack TRC-502 cb radio
Here is the owners manual I'l see if I can get my hands on a internal schematic
http://support.radioshack.com/support_electronics/doc62/62220.pdf
Posted on May 14, 2008
J Kitch
  • 84 Answers
SOURCE: t-mobile blackberry "radio path unavailable" ??
Perform the following steps to try and resolve the issue:
  1. Remove the battery cover.
  2. Remove the battery (while the device is still powered on).
  3. Remove the Subscriber Identity Module (SIM) card.
  4. Reinsert the SIM card and the battery to reset the BlackBerry smartphone.
Posted on Oct 05, 2008
Rayborn
  • 92 Answers
You will need to reload the software onto your Pearl. You will need to download the blackberry desktop manager software and the appropriate handheld device software. Click Here to access T-Mobile's blackberry page.
Posted on Feb 03, 2009
SOURCE: Radio keeps turning off
I had this problem last year ... very annoying to say the least.
It turned out to be my battery, it's was saying charged but was not.
I know it sounds far fetched but try switching with someone elses battery, or grab a new one in the store to try for a minute. You may also be able to try using your phone while it is plugged in. If the battery is not too far gone this will work to prove the battery is the issue.
It worked for me and I have heard of others having the same success by switching batteries. The girl that figured this out for me told me these batteries are not meant to be charge for long periods of time, and that plugging the phone in as you go to bed is what was harming mine. This I can't back up, but she was on the money with my other problem so she may be right?
Good luck
Posted on May 12, 2009
Why wont my scanner model 60 channel pro-2029 scan
Hi Chad,
Do you have any frequencies programmed into your radio scanner?
If not, then that is why you're not receiving anything.
If on the other hand you do have frequencies programmed, are they the correct frequencies for your location?
Are the frequencies the Tx or Rx frequencies that you programmed, The Tx frequencies are the correct frequencies to program, as Rx is the mobile(usually) Tx frequencies, and unless you're within 5 miles of that mobile, you won't hear it, and you certainly won't hear the base transmissions, unless it's a high powered Simplex Frequency.
I hope this has been useful to you.
Cheers,
Peter
Mar 15, 2013 | Radio Communications
Vox mobile ...
What Make/Brand & Model number is your radio?
Without this info, we can't help you.
Please reply with the require info, and we'll do our best to FixYa radio probs. No two radio brands are the same, and the more info you give the easier for us to get you the help you require.
Cheers,
Peter
Mar 02, 2013 | Radio Communications
Maxon wire fuses
If a inline fuse in a holder the old one will aside from length have the amperage printed on it---very few mobile radios use larger than a 3 amp fuse-----look on metal ends of old fuse if have it for markings like 3ag 3 250---3AG is size, 3 is 3 amp, 250 is max working voltage (120 is fine).
Oct 24, 2012 | Maxon MCB-30 40-Channels Base CB Radio
I cant talk
You need at least 8 amp power supply
Sep 06, 2012 | Connex 3300 240-Channels Base CB Radio
Why is the Cobra 29 WX ST 40 CH MOBILE CB radio listed as a Base Radio? It is a MOBILE radio NOT a "base station". It is wired for automotive use only, 12 volt not house current. It can only...
thats how they are listed when they put them in the system.. if you look at ebay they are set up the same way everything is listed as a base Go figure.
Feb 28, 2011 | Cobra Radio Communications
How do i program my kenwood tk260
You'll need the Kenwood serial cable and software to program this radio. Your best bet would be to contact a Kenwood Customer Service Representative directly. You should have the the radios in front of you when you call so that you can answer questions about them instead of having to call back, etc.
Kenwood contact information can be found here. The TK-260 radio falls under the "Land Mobile & Business" category.
Please rate this reply if helpful - good luck!
Aug 12, 2010 | Kenwood KNB-15AM,...
Lincoln 2510 has no channel rejection
Sounds like your IF filter is bad they are usually the same in most mobiles if you can not find the original take a used one out of an old mobile to replace yours.
Dec 28, 2008 | Raytheon VHF 53 CB Radio
Nokia 6070 mobile handfree unit not work with mobile
Oct 14, 2007 | Nokia 6070 Cellular Phone
Radio Communications Logo
41 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
