Question about Home
Toilet seat uberhaus # 01335019 Cant take plastic base apart from seat to install on toilet bowl.
    New Friend:
  • 59 Answers
You should not have to take base apart to install. Where the bolts go there are caps that flip up. Insert bolts through seat and bowl and put nuts on from underneath.
Posted on Jan 22, 2019
  • 380 Answers
Here's two things:
Look at the lid, with the seat down. The bolts are sometimes covered with a snap-in plastic cap or flap. If so, pry up with a screwdriver. Then use a screwdriver and wrench to tighten.
If the bolts appear to be cast as a part of the hinge assembly, you should be able to reach around the seat to the back side (no pun intended) of the toilet, and tighten with a wrench.
I sometimes use a 'mirror trick' to get a better idea of what's back there. Just use a small mirror and hold it to where you can see the bolt and not on the back.
SOURCE:
  • 2712 Answers
SOURCE: How to install Toilet Seat
Use a flat head screwdriver to pry open the plastic pieces that cover the screws. Using the same flat head screw driver, unscrew the large plastic screws holding the old seat in place. There are usually plastic nuts on the underside that you can hold on to while removing the screws. Remove the old seat. Clean the area where the screws were and dry thoroughly. If the new seat has an adhesive pad, remove the covering from the adhesive and put the seat in place. Thread the new screws through the holes and attach with the new nuts. If there aren't new nuts and screws, you can use the old ones, provided they weren't damaged during removal. Snap the caps covering the screws on the new seat in place. Be careful not to over tighten the screws! Since they're plastic, they can be easily damaged by a screwdriver!
Posted on Aug 27, 2008
  • 10865 Answers
SOURCE: elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Posted on Jan 31, 2009
dragonsthatk
  • 547 Answers
SOURCE: Jacuzzi Whirlpool toilet EZ33959
any one should fit
Posted on Feb 21, 2009
whytfang
  • 170 Answers
SOURCE: correct tank to bowl gasket for Orion toilet
I would change out the flush valve itself...it will come with the right gasket....it won't cost anywhere near the price of a new toilet...and it will save you time in the long run..good luck and.thanks for rating my effort....the fang.
Posted on May 01, 2009
woobie dog
  • 1273 Answers
SOURCE: Toilet seat connectors mounted on toilet is loose
There should be a way to tighten the bolts without going that far Here's two things:
Look at the lid, with the seat down. The bolts are sometimes covered with a snap-in palstic cap or flap. If so, pry up with a screwdriver. Then use a screwdriver and wrench to tighten.
Hope this gets you going (oops, another unintentional pun).
Best regards, --W/D-- please feel free to rate this solution..thanx!
Posted on Aug 01, 2009
How do I remove a slow close toilet seat from a Caroma Carvelle one-piece dual flush toilet
All toilet seats are done one of two ways;
A plastic or brass bolt underneath are the rear of the bowl.
A removable cap on the top rear of the seat base.
spec sheet is here
http://www.caromausa.com/database/files/library/Caravelle_Smart_One_Piece_Spec_Sheet_989900.pdf
Caroma website, Installation instructions and Contact details.
Caravelle Smart 270 One Piece Toilet
Dec 13, 2017 | Caroma Home
How to replace a toilet seat
There are round and oval seats.... take note of which you need. Back towards the bowls water tank on the toilet seat you will notice two tabs....pop open with a screwdriver. You will see the screws holding the toilet seat in place. .
Reach under the screw there will be a plastic nut. Hold if while you losen the screws with the Screwdriver....remove and replace seat. ... install screws and plastic nuts again.... and your finished. ...5 minute repair
Sep 30, 2014 | Home
Uberhaus dual flush toilet power-assisted
buy a simpler toilet less problems and you will sleep at night
Jul 18, 2013 | Home
Uberhaus dual flush toilet keeps running
The flapper may not be seating properly after a flush. Even though you say the toilets are brand new, something may be askew in the flushing assembly or may have been affected during installation
May 27, 2013 | Home
I'm looking for round buffers that fit below the toilet seat to stop the seat resting on the toilet bowl. The brand is Gala.
Lowes or HD should have that or a specialty shop. Worst case, the mfr. would have that. You can take the plastic caps that cover the bolts that hold down the bowl in place on the floor and secure them to the seat. All you want is it to support the seat. There won't be any sideways pressure on it. It would just slide on the bowl if it did. If the cap is too tall for the seat, then you can grind it down some to level the seat.
Feb 22, 2013 | Home
The toilet seat looks terrible on the underside and on the top it has the worn look. The price of over $400.00 to replace it is crazy. Is there a way of painting , cleaning up or should I buy a a new...
You should be able to remove an old worn out, toilet seat and replace. Usually its two Plastic Toilet Seat Bolts and two plastic wing nuts under the bowl. Most of them are hidden in a Plastic Cap where the seat attaches to the Toilet Base. You unsnap the caps to see the bolts. Make sure to hold the Wing Nuts underneath or they might just spin.
If its a matter of cleaning something because of neglect. I have recently started using new products that I purchased from www.ChristineFrey.Norwex.biz with great success!
I clean the entire bath room with three products and water!toilet-seat-looks-terrible-underside-2a0cfbtak4y3luwyen1qnfe3-5-0.jpg
Dirty to Clean its simple fast and effective.
The products are: my EnviroCloth, Blue Diamond Cleaner and my toilet brush. If you are like me, I never heard of any of this until I saw a demonstration November 2014 by this person who's website I posted above in this response.
Feb 28, 2011 | Herbeau Charleston, White Toilet Seat &...
Can you just buy a toliet seat base??
Im not sure I understand the question so please excuse me. You can buy a toilet seat, and they usually attach to the toilet bowl. If the porceline that the seat is attached to is broken then the bowl will most likely need to be replaced. Most of the time you can replace the toilet cheaper than just replacing the bowl. Hope this helps.
May 09, 2010 | Home
Toilet seat
Here's what I did. Unscrew them as much as possible. Then I used a bolt cutter and hacksaw to cut away as much of the plastic seat holders as possible. I could then remove most of the seat, and get better access to the screws. I then raised the loose screws enough to cut them with a bolt cutter. Soft screws cut easily. The screw heads are now out. Now, tap down on the screw/anchor and it falls into the bowl. It will stay there. The remaining problem is that you need anchors to secure the new toilet seat. Kohler wants $50. I have a usable but loose seat. Never again-Kohler.
I strongly recommend using a boltcutter. A hacksaw will tear up the bowl.
Nov 25, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Sep 06, 2009 | Home
Home Logo
113 people viewed this question
Top Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
