SOURCE: acquiring network address
From the PC you are trying to connect to your wireless router LAN there are two possible causes of these problem.
1. No DHCP Server Available.
2. You are using MAC Filters and the MAC is not defined in the router configuration.
Please verify this and you can easily get through it.
DHCP can be configured over your wireless router also incase you don't have DHCP Servers in your LAN / WAN. Other wise you can go for manual IP addresses.
SOURCE: linksys can't find ip address
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For
Vista, Start, Programs\Accessories and right click on Command Prompt,
select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
SOURCE: Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
SOURCE: my wireless network connection is always saying acquiring network address what should i do
Just wait and you will get an ip address. You will not get one if you are not associated and aunthenticated by the router.
