SOURCE: documents in single space print in double space
There may be a dip switch somewhere on the printer which enables/disables the extra linefeed. If both CR (carriage return) & LF (linefeed) are both enabled, you will get the double-spacing. In years past, I've run a few different Epson dot matrix printers, and seems like they had such a dip switch. Also, on the software end, you may be able to disable either CR or LF- check in your printer driver software.
SOURCE: How to disable the Okidata from printing double space
Try reseting to factory defaults.
Power unit on while holding down "tear" and "FF Load" buttons.
Hope this helps
Dezzi
SOURCE: Trying to type and single space
You can change this by adjusting the line spacing option.
You are talking while typing wright.
You can select the whole document by Ctrl+A.
Right click & select the paragraph option.
You can find spacing & line spacing.
In the line spacing select the numbers as you like.
Its better to use it as 1.5.
And click on ok.
Good Luck.
Live, Love, Laugh.
SOURCE: Spacing
It would help a lot if you gave a make and model. If this is an IBM wheelwriter there is a key in the rt. side of the keyboaed older ones just say space newer ones have line space in green on these you must use the code key and line space.
DickyO
SOURCE: how can i get an
i have a barcode printer zebra z4mplus
i installed the printer but i am not able to print form it suggest me how can i resolved the issue
