Question about Microwave Ovens
Amana Microwave model ACM1460AB
Seems to have lost its heating oopmph. easy cook used to heat a cup of lukewarm coffee to nice and hot on 30 sec, no longer does so.
  • Microwave Ovens Master
  • 9,098 Answers
Weak heating is usually a bad magnetron.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa:
You can find helpful exploded view diagrams and order parts by entering your full model number here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
The manual tells me to test the product by heating a cup of water for 30 seconds
I usually will test a cup of water for 60 seconds and it should be hot enough that you would not want to leave you finger in the water more than a couple of seconds. It would not be hot enough for most people to use for coffee or some other hot beverage but it would be hot enough to burn your finger if you leave it in there for very long. If it is still lukewarm after running for 60 seconds you probably have a problem with some of the major components and depending on the age of your microwave it might be cheaper to replace the microwave with a new one. Hope this helps you!
Apr 12, 2015 | Microwave Ovens
LG microwave intermittently runs
I would try troubleshooting the "defrost circuit". The behavior sounds like the microwave is cooking in the defrost mode, where it actively cooks then stops allowing the food to rotate and the heat to spread then actively cooking again.
Nov 06, 2013 | Microwave Ovens
Heating the cup more than coffee
make sure the stirrer motor located under the outer cover that distributes the microwaves is turning otherwise you will get hot and cold spots in the oven cavity
Apr 30, 2010 | GE JVM1870 Microwave Oven
Everything on oven appears to work, but does not heat.
from what your describing it sounds as if you have burnt the antenna off of the end of the magtube if this is the case if your microwave is no longer under warranty due to the cost of the part you may be better off to purchase a new microwave.
Mar 25, 2009 | GE JE1540 Microwave Oven
It is your cup. The handle density or moisture content of the handle is causing the mwave to heat it. The rest of the cup contains a liquid (coffee?) that is absorbing any heat generated in the body of the cup. Use a different cup!
Nov 30, 2008 | Maytag Microwave Ovens
Everything works...Except for actually heating the food
It has a bad magnetron. This is the tube that provides the microwaves to heat the food. Not too easy to replace yourself but it can be done. Cost of magnetron is probably less than $50 or $60.
Dec 14, 2007 | Frigidaire PLMV168 Microwave Oven
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here:
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Microwave Ovens Logo
112 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
