Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Green vertical line on the right side of screen
Ive got a single vertical thin line on the right side of my sharp aquos screen
  • 1 more comment
  • cogwac Feb 11, 2008
    We have the same green line.  The repair people say they've seen this before.  Supposedly, there's some part to fix it.   I'm not sure of the cost... we haven't taken it in yet, and it's supposed to be under warranty anyway (costco).
  • pcnewbie79 Mar 17, 2008
    i have a vertical green light on the screen....its a compaq presario r4000 please help me out email is papichulo@prtc.net thank you
  • jim graveson
    jim graveson Jan 13, 2014
    this is a reply to the clever person who has just saved me an expensive call out from an LG ENGINEER i had developed a very thin pinstripe line down the tv that became very annoying after ringing LG and speaking to someone who just wanted to do factory re-set and hope it worked i decided to take the advice off the person who said to bang it on back ???????????? so i did and what do you know it worked ??????? so it would seem that technology has NOT changed much in the last 50 years BECAUSE thats just what we used to do when i was a young un watching crackerjack IF THE TV WENT WONKY GIVE IT A CRACK cheers matey you should get a job on LGs helpline many thanks .......JIM
If someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
Posted on Sep 28, 2008
I bumped my screen by accident recently and now have a similar problem (multiple vertical and horizontal thin lines). I was told that the screen is now bad and probably cannot be repaired. The cost of replacement is more than the cost of a new set. Sorry, but that may not be the answer that you are looking for.
Posted on Dec 10, 2007
  • ken witover Oct 19, 2011
    It is OK appreciate the response, this is a new set out of the box two weeks ago and only used for the first time late last night. Not a very good advertisement for Aquos, but I'm sure they will have it replaced.
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Posted on Jul 09, 2008
Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Feb 28, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I have a sharp aquos 52" with a thin vertical red line in center
If you have a thin line running down the screen, you may be looking at a service issue right off of the bat. Here is a few things I want you to try before calling sharp, 1. Reset the unit from the setup menu
2. Unplug the unit for 2 minutes then plug back in. If that does not work. Take digital pictures of the line and call sharp immediately. Make sure you tell the rep you want to sign up for the aquos advantage program that they have(extends your warranty 3 months free of charge!) because that will get you priority service on with your issue. If they cant resolve that line ,9 times out of 10 they will replace the unit. hope this helps you
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green vertical lines
Possibly needs a new control circuit board or lcd panel
Jun 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Thin blue line
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Green line
sharp is very aware of the panel and main video processor problems.They should give you no problems on the repair.It sounds most likely you have a main video processor problem.
Mar 13, 2008 | Televison & Video
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
3,232 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
