Question about Archos Jukebox AV120 20 GB Digital Media Player
Drive belt replacement
Need to know how to replace the drive belts on a wurlitzer 3000
    Champion:
  • 211 Answers
If I remember correctly there isnt an easy method. You really do have to unravel it like a chinese puzzle around those two rollers at the back of the turntable spindle.
Have fun.
Dave F.
Posted on Jun 25, 2009
  • Dave Jukebox Aug 22, 2009
    There is no easy way. You have to thread it over the rollers at the back.
How do I put on belt? cleaning lady took old one off so I'm lost. It's a hoover turbo 3000.
Assuming this is an upright vacuum, the belt is located under the bottom case and runs between the motor drive pin and round the brush or beater bar. After removing the screws to expose both of these pull up on bar, wrap belt around moter drive, replace idle side of bar, insert bar into belt and stretch to drop into place.
Mar 23, 2015 | Hoover Vacuums
1998 nissan maxima 3000 v6 drive belt diagram
You forgot to mention "with A/C" or "without A/C". Here are both drive belt routing diagrams.
Jan 24, 2012 | 1998 Nissan Maxima
Need drive belt diagram and instructions for replacing the drive belt on a craftsdman dlt 3000 lawn tractor.
Your mower will have a model number like this one:
917.275820 The pictures in the manual below are for the 18.5 - 20 Hp 42 inch deck riding mowers.
It brings up this manual: (3.71 mb)
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0411347.pdf
See page 23 under service and adjustments for deck belt routing picture.
Thanks for choosing FixYa,
Kelly
Jul 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My Sonata GL is at 105K; in the maintenance schedule it is recommended to replace the timing belt. 1) If this particular belt breaks what would be the damage? 2) How much leeway do I have, eg.:100 miles,...
Timing belts are typically only used on overhead camshaft engines. Timing belts are used to synchronize the crankshaft with the camshaft, similar to a timing chain on an overhead valve (pushrod) engine. Unlike a timing belt, a timing chain will normally last the life of the engine without needing service or replacement. Timing belts use raised teeth to mesh with sprockets to operate the valvetrain of an overhead camshaft engine.
Whenever a vehicle with an unknown service history comes into your repair facility or is recently purchased, here are some points that should be asked to help prevent costly engine damage:
* Does the owner know if, or when the belt was replaced-
* If the vehicle purchased is used, or the condition and mileage of the last timing belt replacement are unknown, it is recommended to inspect, replace or at least inform the owner that the vehicle is equipped with a timing belt.
* Note the mileage of the vehicle. The average replacement interval for a timing belt is approximately 60,000 miles (96,000 km).
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
Removal & Installation
1. Raise and support the vehicle.
2. Remove the engine splash shield.
3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
4. Remove the drive belt from the alternator.
5. Slowly release the drive belt tensioner.
6. Remove the drive belt from the accessory drive pulleys.
Fig. Accessory drive belt routing - 2.4L engines
To install:
1. Install the drive belt to the accessory drive pulley.
2. Rotate the drive belt tensioner clockwise.
3. Install the drive belt to the alternator.
4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
6. Install the engine splash shield.
7. Lower the vehicle.
Hope helps.
Dec 22, 2010 | 2005 Hyundai Sonata
How much does a timing belt cost? and what could I expect to pay the mechanic on a 2002 Kia Rio Cino
The timing belt is not the big cost,if the belt has broken while you where driving the car the you may need to spend up to $3000 dollars to repair the damage caused by a broken belt.If your belt is not broke and you have over 50000 miles then get it replaced,expect to pay about $600-$900.This is dependant of labour rates and problems occurred during the repair,your price may be lower.
Feb 17, 2010 | 2002 Kia Rio
Need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to replace a drive belt on a washing machine
You need to slacken the motor bolts, this will then hinge closer to the drum to help release belt. Some belts are still a bit tight even with the motor loose.
Jul 05, 2009 | Washing Machines
Toyota echo 2000 - airconditioner belt squeaking
well the belt could be loose or the compressor may be seized.....or the belt may be old and squealing.
Jun 09, 2009 | 2001 Toyota Echo
I have a old antique wurlitzer and the records are playing very slowly what can be causing this
Bad drive belts.
Motor needs servicing (most likely).
Hasn't been converted for 50 Hz.
Dave F.
Nov 26, 2008 | Wurlitzer Jukebox 1015 One More Time...
1994 Corvette Cassette/Radio?Replace cassette "drive belt"??
Donne Trav, you can take that belt to an electronics shop (your neighborhood shop is best). They will most likely have replacement belts. They will also have a tool that measures the belt so you know which size to get. I used to fix T.V.'s and VCR's. Its the best method when you cannot source an original belt. As far as the diagram, I would need a model # of the radio to even start a search for such a thing.
May 16, 2008 | 1994 Chevrolet Corvette
Archos Jukebox AV120 20 GB Digital Media Player Logo
118 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
