Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Will not read or format.
When inserted, it is correctly recognized as another disk letter(J:). However trying to open it gives the error "J:/ not accessable. Incorrect function." Attempted to format, but the process ends with the error "Windows was unable to complete the format."
I had the same problem with a 1 gig Cruiser Micro and I did something that brought it back to life...I used the U3 Uninstaller on it even though I had already done so and it was already gone and I was then able to open the flash drive and write to it again...go figure!
Posted on Feb 05, 2008
    Problem Solver:
  • 19 Answers
Is windows able to read other usb flash drives? If so, i'd exchange the drive at the pointy of sale.
Posted on Nov 30, 2007
Having transcend 4 GB pend drive but when i insert into my laptop the drive did not open
When a pen drive isn't recognized it is either the pen drive or the usb port. First thing is to try it in the other ports. You can try rebooting the computer with the drive not connected and see if it finds it. Next try it on a different computer. If it finds it then the problem is on the usb port on the first computer.
If it is not recognized on any computer then the pen drive has failed and it is unlikly that you can do anything but replace it with a new one. If it is recognized but not being read on any computer you may be able to use the systems error checking tools to correct the problem and use the drive again. You can also format it and get it working but you loose your stored information.
To use error checking:
Detecting and repairing disk errors
  1. Open shortcutcold.gifMy Computer, and then select the local disk you want to check.
  2. On the File menu, click Properties.
  3. On the Tools tab, under Error-checking, click Check Now.
  4. Under Check disk options, select the Scan for and attempt recovery of bad sectors check box.
note.gif Notes
  • To open My Computer, click Start, and then click My Computer.
  • All files must be closed for this process to run. If the volume is currently in use, a message box will appear prompting you to indicate whether or not you want to reschedule the disk checking for the next time you restart your system. Then, the next time you restart your system, disk checking will run. Your volume will not be available to perform other tasks while this process is running.
To format it: use the same instructions and instead choose the format option.
If none of that makes it behave all you can do is replace it.
Aug 10, 2010 | Computers & Internet
It can not open even there are 325 pictures in memory card it shows (error cf)in my camera, and while connecting with computer shows empty another option apear (the disk in drive G is not formatted, Do you...
Unplug your camera from the computer. Restart the computer. Select a different USB port and insert the camera again after boot. See if you can access the media. If you can't. Try inserting the card into a card reader on a different machine. If you still can't read it, insert the camera into your computer and then go to a command prompt. Type chkdsk [letter]: /r
Where the letter is the letter assigned to the media.
Aug 02, 2010 | Computers & Internet
DT mini Slim 4GB not working
run this command:
c:\format xx:\ /FS:FAT32 /A:4096
Substitute "xx" for the drive letter that windows gives to the Kingston DT Mini 4GB.
It worked for me after using it as a Jolicloud Live Bootable USB.
Sep 28, 2009 | Sony Computers & Internet
DVD CD-R drive does not recognize a blank CD on toshiba sattelite
Try this before you enter disk.
  1. setup software or files to transfer when prompted to enter CDR, then place in drive.
  2. Or open my computer, select cd drive right click select, format disk. When prompt comes up for disk insert CDR.
Some systems have trouble with other manufactured formatted disk.
Mar 06, 2009 | Toshiba Computers & Internet
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
I can not access data on pen drive
1. Download this tool:
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Dec 29, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
DVD-Rom drive doesn't work.
right click my computer .. manage.. storage.. disk management. unalocated. its totaly empty . create partition then format it ntfs and name the volume uhhhh USB160GB for easier to recognize
May 17, 2008 | Maxtor Hard Drive
My pen drive get detected and when click to open it shows the message: " PLEASE INSERT THE DISK INTO DRIVE I"
my pen drive get detected but i am not able to format and copy things to my pen drive
Mar 26, 2008 | Pen Drive IVO MP3 Player
Problem detecting transcend pendrive
On opening my pen drive it displays "Pl insert a disk in drive G
Feb 16, 2008 | Transcend T.sonic 612 MP3 Player
Toshiba DVD player
Does this happen with all discs? What disc are you inserting that gives this error? DVD?
Feb 05, 2008 | Televison & Video
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
585 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
