Frigidaire Portable Air Conditioner
Problem for Frigidaire (FAP094P1Z) Portable Air Conditioner
Had a question, can you place the two hoses that
By cameras12345 on Aug 04, 2009
Had a question, can you place the two hoses that drain the access water in a bucket rather then place the hoses out a window the drain?
Solution #1
posted on Aug 05, 2009
Not Rated)
rollpoll
Rank: Guru
Rating: 90%, 44 votes
Hi, yes you can, but make sure bucket is big enough to fetch all water from machine, always keep hose same level with water in tub, when machine is in operation. lowering hose to floor could get water out by gravity. it's better to put drain hose in sinks, or some form of plumbing, work machine, don't let machine work you, but if it's more convenient for you to drain in bucket, sure, it's o.k. good luck.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire Portable Air
Questions and Unsolved Problems for Frigidaire Portable Air
Do you recommend Frigidaire (FAP094P1Z) Portable Air Conditioner?
Answer
Answer
Our Frigidaire FAP094P122 is leaking. At first I traced it to a pinch in the black drain hose. By... (More)
Answer
The water reservoir fills up and the pump no longer drains it.  The problem just began and... (More)
Answer
Hello there. I would like to seek views on this really cool product from Plasma Cool portable air... (More)
Answer
I just bought the Frigidaire Portable Air Conditioner and it is making a very loud sound. There is... (More)
Answer
the air conditioner freeze then the water leaks out on the floor it does not drain through the hose
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , AK
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
