Question about Dell Wireless Keyboard Optical Mouse w0147
Dell wireless mouse/how to open case to install new batteries?
Model number: m/n:m-r88-del4
  • 59 Answers
Re: dell wireless mouse/how to open case to install new...
I cant look up the model number you gave. but check out this link. this might help. it contains all the manuals for dell peripherals.
Posted on Nov 27, 2007
0 characters
3 Points
I have the dell wireless Y-RBP-DEL4 KEYBOARD is there any warning light on it to say i have caps lock on
Unfortunately there are no lights on the keyboard, which is ridiculous if you ask me!
You can however download a driver from the Dell website that will add a Cap Lock, Num Lock and Scroll Lock notification to the taskbar area.
You can get the driver here.
Hope this helps,
May 01, 2010 | Dell Keyboard/Mouse
Dell wireless keyboard - one button controls at top not working
You will probably need to set up those keys. If you have an installation disc that came with the keyboard try to install the software.
If you don't try going to control panel and then go to keyboards to see whether you can modify the keyboard settings.
Feb 08, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My dell wireless keyboard doesn't work the mouse works. They are linked into the same USB reciever. There is a red light for the keyboard and green for the mouse....I have tried all windows diagnostics,...
try to delete the Bluetooth keyboard and mouse, then search/create a new device and see if they are detected. if yes, just follow the instruction on installation. else, there could be a problem on either of them. hope this helps
Oct 31, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless keyboard and mouse not working, battery in receiver?
The receiver should not have a battery. It gets its power from the USB port. Try uninstalling both keyboard and mouse via (Control Panel...Device Manager) and reinstalling them. Sometimes the drivers get corrupted and reinstalling them will fix that. Also there are on/off switches on the mouse and maybe the keyboard. Check that someone hasn't turned them off to save batteries when not in use.
Sep 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
I am unable to open the case of my Sitecom wireless optical mouse and install batteries
Try the mouse cover behind the Left & Right keys. Put a slight amount of pressure on the cover where your hand rests and slide to the rear. Some of the new mouse batteries are under that cover. Worth a try. Hope this helps. Bud
Dec 30, 2008 | Keyboards & Mice
Install mouse
most of the time, dell components (on a dell computer) will have the drivers pre-loaded on the system. follow the directions that should have come with the mouse for plugging in and synchronizing the component. Normally this involves plugging in the "connection" unit to a working USB port on your system and pressing the "sychronize" button on the unit. Make sure your mouse has good fresh batteries in it otherwise the sychronization will fail. You should get anywhere between 4 and 10 feet or range with your wireless mouse if it's operating correctly.
Also, if the drivers are NOT preloaded on the system, there should be a driver disc that came with the mouse, insert it and install the drivers for your mouse on your computer prior to following the above advice.
Jun 28, 2008 | Dell wireless keyboard and Mouse ( t0179)...
Dell optical wireless mouse locking
If your mouse is "locking" the two most likely causes are either due to a battery issue or a connection issue. The first is unlikely since you're saying it started just after you replaced the battery, but you might want to try again if you have other new batteries around that you can use. Also you could try Re-Pairing (if you have the bluetooth wireless keyboard/mouse combo that dell offers) the keyboard and mouse after reboot. step by step Instructions for re-pairing or fixing a corrupted are should be available on the Dell support website and vary depending on the exact model you have.
Jun 28, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Dell Wireless Keyboard Optical Mouse w0147 Logo
1,659 people viewed this question
Top Dell Keyboards & Mice Experts
 Mike M
Mike M
Are you a Dell Keyboard and Mice Expert? Answer questions, earn points and help others
