Question about Sony PlayStation 2 (PS2) Console
Disc No Read
Shut down unit last night. Tuned it on this mornin' and get " Disc No Read" error message. Please post answer these pages.
Thanks in advance, Razor6
  • 116 Answers
Re: Disc No Read
Ok this is a common problem with the PS 2 and even when you use a wet or dry system it does not work. You will have to open that baby up! Here is a link that spells out exactly what to do! I recommend you are confident before trying. I did it to my PS2, have not had a problem since!
Good luck, it worked for me!
Posted on Nov 26, 2007
0 characters
3 Points
Wii wont read disc's. It says,"An error has occurred. Press the eject button and remove disc, then turn off Wii and refer to operation mannual for help trouble shooting. Thanks for your help. ...
I'm with you Jordan. Mine just gave me this message for the first time last night. I'm desperate for a solution. I may try replacing the laser...less than $20 to do.
Just out of curiosity, what were you playing when you got the error? It wouldn't happen to be COD Black Ops, would it?
Nov 29, 2010 | Nintendo Wii Console
When i turned my Ps3 on this mornin i changed the disk and put anouther game in. its been doing the spinning line in a circle thing for the last 10mins. it was working fine last night. plz help!
Either bad laser or dirty laser. Take your console apart if you dont have a warranty break down the disc drive metal case and wipe your laser with a q tip and rubbing alchol not to wet though kinda wipe qtip on ur arm to get most of the alchol off the qtip so it wont pour into the laser when you wipe it off. hopefully that works if not its a bad laser.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
I got my Wii recently, when i try to insert a disc to play a game, the error message "Error reading on disc, please refer to your nintendo operation manual", the display of this message, i can't do...
forcing the system to shut down won't cause problems. The main issue here is that the laser probably is bad in the drive.
Take a can of air and gently blow some into the drive. This will make sure that there is no dust or dirt on the laser.
Try to a few discs in the drive and if it still doesn't read it then that means the drive is bad and you would need to either replace the laser or the drive itself.
Dec 02, 2009 | Nintendo Wii Console
You may have dust on the Blu-ray lens. The lens has 3 different wavelengths, one for games and bluray cds, one for cds and one for movies. The best thing to do is to use a disc cleaner which you can buy down at your local electronics store. The cd contains small brushes which clean the len of dust and dirt. Also try removing as much dust of your unit as possible as playstation 3 consoles are dust magnets.
Jul 29, 2009 | Sony Playstation 3 (PS3) Console
Wii will not play any of my games discs
Made a video showing how I fixed this exact problem on a Wii.
Mar 20, 2009 | Nintendo Wii Console
Wont read discs
Downloadable games are not playable on PS2. If you're trying to play pirated games that you've downloaded from the Internet you're going to need to have your PS2 hardware modded to play DVD-Rs, which is expensive, dangerous, and illegal.
Jan 03, 2009 | Nintendo Wii Console
I got wii fit the disk wont work !!!!!!
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 27, 2008 | Nintendo Wii Console
The Wii will start up and read the disk then give an error messag
Had the same problem and I made a video going through the troubleshooting process and how I ended up fixing it by replacing the DVD Drive.
Dec 26, 2008 | Nintendo Wii Console
Cannot read disc
I had the same problem with my Wii. Unfortunatly nothing worked to fix the problem so I called Nintendo's customer services. They were able to replace the unit free of charge. I would simply give them a call: 1-800-255-3700 and press 2.
Good Luck,
Jun 05, 2008 | Nintendo Wii Console
WiiSports disc can not be read
Send it to Nintendo for Warrenty replacement.
Apr 22, 2008 | Video Game Consoles
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
