Home | Krups | XP 1500 Espresso Machine & Coffee Maker | Espresso used to run too...
Krups XP 1500 Espresso Machine & Coffee Maker
Problem for Krups XP 1500 Espresso Machine & Coffee Maker
Espresso used to run too much water through, now not enough
By qwestr1 on Aug 04, 2009
I fill the 2-cup thing full to almost the rim, then mash it in using the circle on the end of the scoop thingy. I learned not to smash too hard, as my machine doesn't like that.
After it has warmed up, I put the espresso "bowl" thing with the handle onto the machine, locking it in place.
I then hit the 1-cup button, and less than 1 shot of espresso comes out before it beeps several times, and the lights flash on and off repeatedly. It seems angry when it does this. I wait a couple minutes, then try again, and finally get a full shot of espresso.
What am I doing wrong? I'm just trying to get a double-shot, but it now barely gives me 1. I even replaced the little metal cup thing with a new one, no change. I switched to pre-ground espresso in case it was the grind being too fine, but still not better.
Did I buy a bad machine???
Popular Solutions for Krups XP 1500 Espresso Machine
Questions and Unsolved Problems for Krups XP 1500 Espresso Machine
Do you recommend Krups XP 1500 Espresso Machine & Coffee Maker?
Answer
Answer
Hi, I just purchased the Krups XP1500 Coffee and Espresso Combi Machine. The coffee side works... (More)
Answer
My coffee and filter are in place, the water is in, the bottom gets very hot....but no coffee... (More)
Answer
how do you assemble the axle and the filter holder into the xp1500 expresso and coffee maker?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Krups XP 1500 Espresso Machine...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
