Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Solution not being picked up
I have checked every possibility - w/the watertank being aligned etc. Solution and water comes out but is not being extracted. Belt works, etc. Help!
  • Norah Nov 26, 2007
    My Bissel heated steamcleaner was given to me recently but not with a product information booklet.So when it wont extract the cleaning floid from the carpet I have no idea what is happening (or not happening)
    Norah
    President:
  • 1,673 Answers
Is the filter inside the lid of the tank clean? Is there a gasket between the tank and the top of the clear window. If you take the tank off, and run the machine, there should be suction coming from the square shaft, but if there is a clogged filter, or that gasket is missing, it will loose that suction and won't extract the water.
Posted on Jan 06, 2008
  • lmkelly Jul 30, 2011
    I checked it and there is no suction there either
Rainbow e series shooting out dust
Did you place water in the water pan? Are you picking up drywall dust, baby powder, wood ash, etc.? This type of material is difficult to be trapped by water.
RainVac
www.rainvac.com
800-523-0510
Mar 31, 2012 | Rainbow E series Canister Wet/Dry Vacuum
No solution comes out
- Please check the water level in the tank. It is imperative that the water level be at the full line when beginning your cleaning. Because this machine is gravity fed; if the water level drops too low, there will not be enough pressure to release the fluid.
- Please make sure that the siphon tube for the autoload insert (on the water tank) is perfectly aligned with the front and back of the tank. If the tube is turned to the right side or the left side of the tank the unit will not spray.
- Please check the vent hole on the tank. This hole is clearly marked and the water level must not be above this hole. The vent hole must also be clear.
- Please check the spray bar on your machine. The spray bar is removable so you may take this off if desired and inspect the spray holes to ensure that they are clear.
-Try removing and reinstalling the handle/screw assembly. The trigger mechanism is contained inside the handle. Occasionally it is possible for this part to become misaligned. To check for proper handle installation, try turning the handle from side to side and try to pull the metal part of the handle up or down....if properly installed neither of the previous actions should be possible.
Oct 21, 2010 | Bissell 2090 QuickSteamer Upright Vacuum
Won't pick up the water while cleaning
Please check two three things:
(1) Is the lid on the recovery tank aligned to the tank at rope seal of lid?
(2) Is the rectangular panel in place in the front of the recovery tank, that connects the clear nozzle to the tank lid?
(3) Remove the tank from the base, and check and see if a round black gasket is in place on the round tube that comes up to the front corner of the bottom of the recovery tank. This is a vacuum seal to connect the motor to the tank to supply suction.
Oct 13, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steam cleaner will not pick up the water the machine pu
Two checks:
(1) Is the lid aligned and sealed to the recovery tank
(2) Is the round rubber gasket installed on the tubular post under the hood, where the tank seals to the base? The tube extending down from the tank must sit on the rubber seal to get vacuum from the motor.
Sep 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have the bissell x2 12 amp carpet shampooer
The water should be picked up fairly rapidly into the area surrounding the clean water bladder. Try checking the lint filter to fix your suction problem. It is located in the top clear plastic section (the one with the dial to switch from tool to floor use). One the under side of it there is a small (1 inch square) red filter with a little door on it. Flip open the door and it is probably clogged with hair, carpet fibre. etc.. Clean it out and you should have suction.
Jul 09, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
9500 doesn't pick up water
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is a small (1 inch square) red plastic filter with a door on it. Flip the door open and it is probably clogged with hair, carpet fibre, etc.. Clean it out and hopefully you will have suction once again.
Jun 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Floormate will not **** dirty water.
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Apr 20, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
** suction
You have an airflow problem. You may still have a blocked intake or tube, also check the filter. The air is supposed to go in the bottom (of course) and I'm sure you k**w where it goes out. You probably can **te a reduction in exhaust. If this is a bagless make sure everything is fitting together properly. Mis-aligned components on a bagless can mean little or ** airflow. If this is **t a bagless, try changing the bag whether it is full or **t.
Mar 10, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
222 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
