Question about Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Cleaning Hi there! I was out hunting ysterday and by an accident i fell and filled my Zeiss witg mudd/ clay. do you have any good cleaning tips. warm/ cold water? using alchohol? / Christian Edlund from Sweden
  • 22 Answers
Re: cleaning
I hunt in Wyoming so I understand your dilemma. I recommend using running tap water to take off the clay and mud. Let dry and repeat if you need to. That will allow the bonds the clay and mud have on your scope to loosen and fall away between rinses. This will save your scope's finish. When you get ready for your lenses take extra care! I use ammonia free towelettes i get at the local electronics store to leave a streak free shine on my lenses. Using ammonia or alcohol will break down and ruin the fog proof and water proof coatings you can enjoy with your optic now. Otherwise that's the best recipe for getting your optic back to 100%
Posted on May 06, 2008
0 characters
3 Points
Dont understand why on top of an side of scope setting there is ur ur instead of left right or up down
The "U" indicates Up on the elevation dial, and the "R" indicates Right on the windage dial. Turn the elevation dial clockwise to move the point of impact up, counterclockwise moves down. Similarly, turning the windage dial clockwise moves Right, and counterclockwise moves left. Here's a scan from the Zeiss Conquest manual:
Jan 05, 2011 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Zeiss diascope coarse adjustment
sounds like you lost the locking Allen screw.
need that to sort your problem.
Jul 11, 2008 | Zeiss 528013 / 528015 Diascope 85
Can you tell me if Model 78-1518 is suitable for astronomical use, does it mean images will be upside down? It is for someone just starting to do a bit of star gazing. Is this model a reflector or a...
This is a spotting scope, mostly used in conjunction with firearms on the firing range or maybe hunting. It is a terrestrial refractor scope and shows erect images (the right way up). It isn't really ideal for astronomy.
One would generally want a larger diameter objective and a simpler eyepiece system (not a zoom) for stargazing. Some people start astronomy with a pair of binoculars (7x50), which would be as good or better than this for the purpose. Eventually you will want to see faint objects which requires a larger objective (main lens or mirror) to gather enough light and give good resolution. The upside down thing doesn't matter when looking at stars.
Dec 03, 2010 | Bushnell Sentry 78-1518 (18-36x50 mm)
On my ziess conquest, what turning knobs do what? which one makes it go up and down and which one makes it go left and right?
The top knob should be marked with a "U" and an arrow pointing clockwise. Turning this knob clockwise should adjust point of impact Up, and turning it counter-clockwise should move it Down.
The knob on the side should be marked with a "R" and an arrow pointing clockwise. Turning this knob clockwise should adjust the point of impact Right, and counter-clockwise is Left.
Nov 09, 2010 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Gun was loaded with a bb and pumped 10 times, I
go to an outdoor shop or a hunting store
Mar 30, 2010 | Crosman (4032)
The circuit board that holds the batteries for my ETX is corroded and I need a new one. How can I get one?
Is the problem that you left the batteries in the battery compartment? (a no-no, BTW.)
If so, you might get away by cleaning the board--if the circuit traces and components haven't been damaged.
Try mixing a tablespoon of backing soda with a cup of warm water. Using whatever applicator seems appropriate--a Q-tip, or small brush--clean the corrosion from the board with this solution. Wipe and dry thoroughly.
Inspect the board for broken circuit traces and damaged components.
If nothing is obvious, put fresh batteries in and try it--it will work, or it won't.
If it does, congratulations. If it doesn't contact Meade customer support at this link:
Good Luck!
Mar 25, 2010 | Meade ETX-90 (48x90 mm)
I have a Winchester 7600 from the late 60's that I have never fired. I have just stored it here at home and never really had a use for it. I do not even know what type of ammo it takes. Can anyone tell me?
I think you will find that you have a Remington 7600 pump action rifle chambered in a Winchester calibre round. There may be something inscribed on the barrel with Winchester on it. The numbers with the word Winchester EG: .308 will denote the calibre. Just like a .38 revolver will have .38S&W on it regardless who manufactures it. The name S&W indicates the original patentee of the round. So your Remington 7600 is chambered for a Winchester patent round. The number with it such as 308 or 243 will tell you what ammo it takes.
Aug 01, 2009 | Zeiss CONQUEST 4.5-14X44 AO MATTE Z PLEX
Tasco Rifle scope repairs
Try calling Customer Service at 1-800-423-3537. They should be able to assist you with your needs.
Sep 22, 2008 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Crosman airguns 357 6 shot
What part are you having trouble with?
I have had mine apart several times trying to repair a leaky valve.
Could possibly make a you tube clip.
Dec 26, 2007 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Zeiss 3 x 9
Gusbear, here is the whole shebang. document.write(mdec('c#6#8#9#5m#3r#0#8#3rv#7c#3#1v#7#8#7#5#4#0z#3#7#8#8#0c#5m')) this is for their sandiego offices
Carl Zeiss Optical, Inc., Chester document.write(getAddressCountry('US','USA')) document.write(t_phone) Phone: +1 800 441 3005
document.write(t_fax) Fax: +1 804 530 8333 form.gif document.write(t_inq) Inquiry
email.gif document.write(mdec('#8p#5r#9#8#5p#9#7c#8#1z#3#7#8#8#0c#5m'))
this is for the sport optics contact you are looking for. give them a ring or drop a line, they should be able to help you out.
Dec 01, 2007 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
99 people viewed this question
Top Zeiss Spotting Scopes Experts
Michael Thomas
Michael Thomas
Are you a Zeiss Spotting Scope Expert? Answer questions, earn points and help others
