Question about Apple PowerBook G4 Mac Notebook
Sound f3 f4 or f5 functions dont work to change volume, when pressed, a block sign appears, cannot hear any sound through laptop speakers, But when i put the headphones in, it works perfectly fine, Also wer da headfone goes into the socket, there is a red light all da time, how do i get ma laptop speaker sound to work??!
  • 34 Answers
Re: Sound
I have heard of this problem before. If the red light is always on the headphone jack might think there is something still in place. You could try blowing any dust out with a can of air before you perform and archive and install.
Posted on Jan 25, 2009
  • 382 Answers
Re: Sound
The red light is because its a digital/ analog output. Its known as s/pdif..Sony/Philips Digital Interconnect Format- also known as TOSLINK or lightpipe.
it sounds like you may need to reset the nvram / pram on your computer. If this doesnt not work, then you may need to reinstall the os. it's known as an archive and install. Have you recently done any upgrades or installs? Do you write music and may be using an external sound card? you may want to go to system preferences, choose sound, and make sure the onboard ins and outs are being utilized. but the fact that youre not getting the proper on screen icon representing the sound level would indicate and issue with the hardware engaging with the software.
Before you attempt the archive and install, I would make sure you have the most recent version of your OS....
Keep me posted...
Posted on Nov 27, 2007
0 characters
3 Points
How do I unlock the speaker on my PowerBook G4?
You probably pressed F3. Press F4 or F5 to unlock the sound. If that don't help then you gots to open this puppy up and clean the dust off the speaker connections and around the speakers. If that don't help then you should replace the speakers. If that don't help then you should replace the sound/power board. Have a pro do it if you don't know how.
Aug 20, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
I cant hear my buddies when using ichat but they can hear me perfectly and clearly.. Also I cant get sound when using quicktime especially with .avi files.
This is easy..
Your buddies need to raise their microphone volume, which may be muted. System preferences, sound, look for the microphone slider and raise it to full.
Quicktime doesn't like AVI's by default, and even when it does work, it usually won't play the sound. There are two solutions.
1. download 'flip4mac' which is a quicktime plugin for playing AVIs (
2. Download VLC, which plays everything, and has the excellent feature of raising the volume to 300% (great for crappy laptop speakers).
Jul 06, 2010 | Apple MacBook Air
My laptop has that problem when i turn it on the screen is just black. please help... ASAP
firstly check if there is any signs of beeping sound when you switch on the laptop.
if not sound that means, you might have a problem with you processor or the mainboard.
but if you hear the beeping sound when booting up the laptop, try to use an external monitor or screen to chcenk whether the system is working fine or not. connect an external screen to the vga com port on the laptop and hold on function key (fn) and press f5 to see if the external screen displays something.
if yes, then you will need to replace the screen and if no, then send the laptop for service
May 19, 2010 | Mac Laptops
Sound wont go on. muted but i have no way of unchecking the mute box
Go to the top of your keyboard. There is a button with a black sideways bell shape icon on it ( a speaker) (the f3 key)...probably four in from the left starting with esc. Toggle that on. It may be on the mute setting now. It should have waves coming out of it when it is unmuted. To the right of that button (two buttons to the right) is the increase volume control button, the (f5) key. Make sure the volume is up! If it is down all the way you will hear nothing and it will be also muted.
I am not sure why if you go into System Preferences (under the Apple icon) and scroll down to Sound and Output, the mute box cannot be unchecked. Perhaps using the function keys to unmute and increase volume on the top of the keyboard will help.
May 07, 2010 | Apple PowerBook G4 Mac Notebook
Hello ..i dont have sound on my macbook air its like deleted ,i tride to reset but didnt work.can you help me out ..tahnks
Go to your system preference panel in the dock... click on the sound control icon. Look down at the bottom of the dialog box... there is a "MUTE" check box....make sure it's unchecked....
Also press the 'fn' key at the bottom left of your keyboard while pressing the f5 key... to raise volume...
let me know if that solves the silence!
Aug 05, 2009 | Apple MacBook Air
No Sound From Internal Speakers
go to prefrence pane select sound then output bar and arrange the volume labeling , can you hear some sound.
Jul 02, 2009 | Apple MacBook Air
Can't turn speakers back on
Hi, a try would be to reset the PRAM by pressing cmd - alt - P - R simultaneously at startup untill you hear 3 startup chimes, then try to change the sound settings
May 22, 2009 | Apple MacBook Air
Volume problems on my Apple MacBook
Hi, Sorry you are having problems,
If I understand you correctly, you have your headphones plugged into the MacBook and are expecting sound to come out of your speekers ?
Well, if that is the case, you must know that the mac will automatically cut the signal to the speekers as soon as headphones are connected.
Now if you are saying that you connected the headphones to test it and found that whe you changed the volume, you could hear the change on the headphones, but when you unplug your head phones, you do not notice any sound difference on the speakers.
SO let's say that is the problem. First thing to always do, of course, is a full shut down and a clean start up with no headphones installed. Once you have booted up, try it again....
If it still does not work, go into your sound preferece pane in the system preferences and change some of the settings, like muting the sound and clicking the button that allows for showing volume in menu bar, unclick options go into the tabs go clicking and unclicking things... then quit and then go back into the sound preferences and set it the way you want, sometimes shaking it up a bit gets it back on track...
Good luck.
Apr 02, 2009 | Apple aluminum 13-inch MacBook laptop-...
Volume only works with headphones in
Hi pujak,
The little red "null" symbol you describe indicates you've got the "Mute" turned on (bypassed by headphones). Either go into System Preferenced/Sound and adjust that, or use the F3 or F4 keys (it's F3 on my MacBookPro) to toggel it on/off.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using,
Mar 26, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Built-in speaker in Mac doesn't work (red light!)
I took a safety pin and put it in the notch inside the headphone jack input. notch is located at 12 o'clock about 1/8th inch in, (this is an important step, other steps are no good until red light is off) the red light went off (Be patient this step may take time) still no sound, I then went to Audio MIDI setup (Should be located in Applications/Utilities), go to Audio in menu bar (at very top of computer screen) and selected 'open Aggregate Device Editor,' clicked on the + to add a device I then had a few options show up in the lower [Structure] portion I clicked on all the 'Use' boxes and the built-in output bubble selected done. I then Selected Configure Speakers in Audio MIDI setup and I can test my left and right speakers individually, they put out a fuzzy test sound, pressed done when finished. They still didn't work so I set Default out put to the Aggregate Device I created, then turned on Itunes and it was working fine I just could not control the volume from the F3, F4, & F5 buttons so I went to sound in system preferences and made sure the built-in Output option was selected. I was then able to control the volume. The red light in headphone jack input may come back on if anything is inserted inside, just mess around with the notches inside till it goes off. Hope it works as well as it did for me. Good luck and please feel free to quote me and share this solution with others.
Nov 20, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple PowerBook G4 Mac Notebook Logo
361 people viewed this question
Top Apple Mac Laptops Experts
 Mike M
Mike M
Louise Nadon
Level 1 Expert
Are you an Apple Mac Laptop Expert? Answer questions, earn points and help others
