Question about Precor Exercise & Fitness
Precor EFX 5.17i. The power comes on and will run for about 30 seconds then shuts off? Could this be a short in the wiring? I recently moved it and disassembled the uprights from the base.
  • Precor Master
  • 1,642 Answers
SOURCE:
SOURCE: TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
Posted on Jul 06, 2007
  • 333 Answers
SOURCE: Craftsman 6hp 150psi 30gal won't keep running
It sounds like the internal circuit breaker in the motor is heating up and then the breaker trips to shut down the motor. This is the protection so you don't have a fire if the motor burns up. The smell you have is the coils in the motor. Sorry to say that you will need a new motor for this unit. I hope this helps out.
Posted on Jan 17, 2009
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
  • 4 Answers
SOURCE: my Flotec pump runs 5 seconds shuts off for 30
fully submerse pump in bucket of water, tilt to get all air bubles out,(keep hose off) plug in and it should work fine
Posted on Apr 03, 2010
maxtreadmill
  • 832 Answers
SOURCE: Need to disassemble a precor 9.31 to move to a new
Remove the motor shroud this is done with a set of allen wrenches, remove wire harness from the lower pcb, then on the console tower which is bolted to the frame with (should be ) 4 allen bolts on each side. Have a additional set of hands so that the upper tower does not tumble down.
Posted on Jul 19, 2010
My Precor EFX 833 elliptical shuts off in the middle of use m, I’ll be in the middle of a workout program and it will turn off
If you are using Electrical power coming from outlet box 110vac, The Power supply inside is defective. Or if you are using batteries, has the same problem with the converter-power supply, Repair or replace.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 26, 2017 | Precor Exercise & Fitness
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
How to fix the display
Start with verifying the battery voltage. Here is a video on how to do this. If your battery checks out, move on to the stride sensor gapping. I will post a link with a service bulletin that shows the stride sensor and it's location. Also, confirm the right crank arm still has the magnet on the backside.
My Precor Elliptical Shuts Down After 7 Seconds what is wrong
Jun 24, 2014 | Precor EFX 546i Elliptical Version 4
Precor efx 576i resets everytime user changes direction
Does the lift work? If not, the battery is dead. Replace it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Feb 17, 2014 | Precor Efx 576i Experience Elliptical...
Efx time out after 7 sec
My Precor Elliptical EFX 546 Timer Stops After 7 Seconds, what is wrong? The most common cause for the Timer to Stop After 7 Seconds on a Precor Elliptical is NO RPM Feedback.
Knowing the status of the unit from its last use as well as the last service or part replacement is a great place to start.
Check the connection of the speed sensor to the lower board. Reset connection if necessary.
Check the magnet. The magnet is located on the user's right crank arm on versions 1 and 2 and the user's left on version 3. The magnet passes the speed sensor with each revolution of the crank arm. The magnet should be installed so that its south pole is facing the speed sensor. You can check the magnet polarity with another magnet that has marked poles or a compass. The north pole of the marked magnet or the south facing needle should be attracted to the magnet. Correct magnet installtion if necessary.
You may also check the spacing of the speed sensor to the magnet. The spacing should be 1/8" to 1/4". Adjust if necessary.
Feb 02, 2012 | Precor EFX 546i Elliptical Version 4
Precor efx 556
Here you will find parts and other information for the Precor EFX 556.
Repair Parts for Precor EFX 556 Ellipticals SPORTSMITH net
Jan 07, 2012 | Precor EFX 546i Elliptical Version 4
My EFX elliptical provides an error 44? and shuts down in the middle of my work out. I notice this is only an issue when choose a course that is weight loss when the EFX has to incline and decline. When...
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Jan 21, 2011 | Precor EFX 546i Elliptical Version 4
No heartrate display
Check the wired connections on the back of the HR grips. It could simply be unplugged. I have also seen them rusted from sweat. Start with this before moving on to other possibilities. I am attaching a link to a service manual for further troubleshooting tips.
http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/Service%20Manual,%20C546i%20Self%20Powered%20EFX.pdf
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Jan 19, 2011 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
94 people viewed this question
Top Precor Exercise & Fitness Experts
Jose Pino
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
